It is currently Mon Jun 08, 2026 10:56 am
 Post subject: Weber Q's
PostPosted: Tue May 30, 2006 11:18 pm
Banishment Pending
Well i finally got a Weber..it only took me almost 2 years :roll:
I have a few q's for those of you that have the Weber.
1. What the heck do I do with the fuel return line???? the Weber doesn't have a post for it
2. Electric choke, my 80 had one stock but it got taken off the carb, all of the wiring is still there I just need to know which wire to hook up.
3. not really a question but I'm making my own mounting plate and will be modifiing the throttle linkage instead of buying the items from Weber. I'll let yall know how it runs after i get it put on this weekend.
PostPosted: Tue May 30, 2006 11:26 pm
Swap Specialist Mod
the return line can be plugged and or removed.
the electric choke can be hook up the stock harness. there should be some wires that went to the stock carb. just find the one thats hot when the key is on. then hook that to the choke on the carb.
for the linkage, take the bellcrank deal from the stock carb and put it on the weber. itll bolt right on. then just mount the cable to the valve cover so its solid.
PostPosted: Tue May 30, 2006 11:40 pm
For the cable I have a chunk of 1/4" aluminum bolted to one of the intake manifold studs. I bent the ends the same angle so that it was in the right position to hold the cable, ended up sort of shaped like a stretched out Z. Something like this:
\____
(ignore the dots)
On the top side where the cable goes through drill the hole then cut a slot to it from one side. That way you can slip the cable in through the slot.
PostPosted: Tue May 30, 2006 11:47 pm
Banishment Pending
Thanks guys
PostPosted: Fri Jun 02, 2006 4:41 pm
Banishment Pending
Hey guys I have another question for ya, I got the carb mounted and every thing all taken care of, but no I need to ture the Weber and i have no clue about how to do it, If some one could give me a little advice on how to tune it and every thing for the 1.8 that would be great, thanks again guys
PostPosted: Sat Jun 03, 2006 11:13 am
These darn newbies, never want to search for the info they need. You'd think when they hit 1000 posts they'd learn... :P
Well, I searched for you and I found a post linking to weber adjustments. Just look who started the post!
http://forums.luvtruck.com/viewtopic.php?t=5584
I declare, that rezkid boy, got a mind like a steel trap: full of mice.
PostPosted: Sat Jun 03, 2006 8:17 pm
lol :lol: :lol: :lol: that is too funny
PostPosted: Sat Jun 03, 2006 9:38 pm
Banishment Pending
:oops: :oops: :oops: :oops: :oops:
I just never learned how to use the search funtion i guess, lol funny stuff that , thanks 800 for putting up with us newbies...even the ones that have been here almost 2 years :oops: :oops:
PostPosted: Wed Jun 21, 2006 12:05 pm
Banishment Pending
Just thought I'd give a little update here, I LOVE THE POWER!!!!!!!!! :twisted: :twisted: next part...header. Thanks to all who helped out with the questions, thats why this is the best site on the web for Luv Trucks!!
PostPosted: Wed Jun 21, 2006 1:36 pm
Swap Specialist Mod
arent they great!! ill never look back! i think they people who made the hitachi carbs even knew that they were gonna be shit, but still made em. lol
glad that its working good for ya!!
Users browsing this forum: Google [Bot] and 58 guests
