It is currently Mon Jun 08, 2026 10:55 am
 Post subject: weber help
PostPosted: Mon Sep 20, 2004 9:18 pm
Banishment Pending
Hey guys I would like to know how "easy" it is to install a Weber carb, I will hopefully be getting one from twist of fate, and would like to know how difficult it is. yes i am mechaniclly inclined, i'v rebuilt the stock LUV carb, and the head on a '88 trooper, and various other things on a '87 GMC Sub. w/ 6.2 diesel, man that truck is a pain in the rear to work on. any way, any help would be nice,
thanks,
TJ
PostPosted: Mon Sep 20, 2004 10:51 pm
It's actually really easy. On a scale of 1-10 I would have to call it a 2 or 3. depends on what the carb has. Mine had the fittings for the fuel return line, so that was easy. Just capped a couple of vacuum lines and it was good. Didn't have the linkage for the kickdown (mine's an auto), so I had to figure out what to do with that. But all in all I think it was about an hour to complete the swap and get it tuned right.
Resident lurker
PostPosted: Fri Oct 01, 2004 1:42 pm
speaking of the weber carb. where is the air fuel adjustment screw? i cant find it anywhere....driving me nuts. i have rebuilt that carb 3-4 times and it still runs like crap. smoking real bad, runs fatter than an opera singer. any help would be greatly appreciated. thanks. :twisted:
PostPosted: Fri Oct 01, 2004 1:49 pm
Try this...
Here
Should be what you're looking for.
Resident lurker
PostPosted: Fri Oct 01, 2004 2:32 pm
thanks that may help a little bit. also does anyone know where i can get a full set of wheel studs? kits? i would have to run all around atlanta to round up all the studs that i need or wait 6 weeks for them to get here from AAP. (they never have what i need anyway)
