It is currently Mon Mar 30, 2026 5:19 am
 Post subject: GTI dash i a LUV
PostPosted: Tue Jan 17, 2006 7:55 pm
today i was bored so i cut out my old dash and decided to put a dash out of a gti in. i picked up the rabbit yesterday to scrap and get some parts for mine.
Last edited by twist_of_fait on Tue Jan 17, 2006 8:21 pm, edited 2 times in total.
PostPosted: Tue Jan 17, 2006 7:59 pm
didn't see any GTi stuff.. but how far off drivetrain wise was the s-10 setup you dropped your body on? it looks like a lot, but i thought it was close to the right lenght and width
PostPosted: Tue Jan 17, 2006 8:02 pm
yeah i just got the picture on after you looked at it. anyways the width was right on but the front of the bed was like 4 inches to long but i fixed that and i did it on a s-10 blazer frame not the s-10 pick up
PostPosted: Tue Jan 17, 2006 8:39 pm
thanks for the info.. and that dash will be a unique one for sure
PostPosted: Wed Jan 18, 2006 12:15 am
Neato!!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Thu Jan 19, 2006 7:27 pm
Make's me wish I was back in "CornValley" so I could come over and check it out! What are you using for a steering colom? I would love (LUV?) to do away with the stock one, and get one that was 3"or 4" shorter.
 Post subject: steering coulmn
PostPosted: Sat Jan 21, 2006 9:42 pm
its a tilt coulmn out of a 92' s10 blazer
PostPosted: Sun Jan 22, 2006 11:32 pm
How big of a pain is the swap?
PostPosted: Mon Jan 23, 2006 7:48 pm
great job with the swap out!
I like it. defenitly different(Ina good way! :)
"Experience is a hard teacher, for she gives the test first, and the lesson afterwards."
1978 Chevy LUV - 2WD - [Work In Progress]
w/1976 1.8L 1815cc Stock Isuzu Motor
http://forums.luvtruck.com/viewtopic.php?t=8843
PostPosted: Wed Jan 25, 2006 2:18 pm
got my gauges in and my wiring tucked away i even have a lighted glove box and entry lights!
as for the swap are you talking about the column or the dash?
PostPosted: Wed Jan 25, 2006 7:26 pm
Well, I started askin' about the collum, but after taking another look at the dash, I want to know about both :!:
Damn that looks good! 8)
PostPosted: Wed Jan 25, 2006 10:05 pm
thanx! well for starters the column wasn't really a swap cause im on a s10 frame so it was a bolt on except for the bracket to mount the column to the dash. as for the dash i cut out the steal dash. then i cut out the dash mounts out of the rabbit and made some 1" spacer out of sheet metal and welded them to my kick panels then welded the dash mounts to that i had to trim off the defrost hole to get the dash to fit right. i might cover the whole thing i fiberglass im still debating it
PostPosted: Sun Jan 29, 2006 11:59 am
My stock dash is toast and I am probably going to build an aluminum dash for my truck, but I did do some thinking and my brother gave me some ideas about using a Fierro dash. My brother was the body shop business for a while and he was saying if you find something about the same size and year from like a GM for example chances are there is another dash that will fit in its place relativly easy. I have never actually researched doing this and when my brother says easy it usually isnt but I have had some thoughts about trying it.
PostPosted: Tue Jan 31, 2006 4:15 am
why did you have to cut up the rabbit! (VW nut) what are you gonna do with the rabbit when your done?
PostPosted: Tue Jan 31, 2006 5:32 pm
yeah there was no title so i scraped it i cut the dash mounts out and all. i have the snowflakes that were on it and im selling them if you know anyone. i took the fender flares and lower valence and put them on my rabbit
