It is currently Mon Jun 08, 2026 6:32 pm
 Post subject: running rich
PostPosted: Tue Dec 13, 2005 11:11 pm
i changed my points, rotor, and dist. cap. when i started it up the luv ran like a champ. Now since i been pullin it in and out of my garage to fix the brake problem i have, i've noticed it is running rich. Could this be from the carb or is it a timing thing? before i changed all that stuff my truck ran like shit, do i have to readjust my carb. for the points or could something else be thrown off? thanks
PostPosted: Tue Dec 13, 2005 11:54 pm
you may not be letting it warm up thus it is running with the choke on.
PostPosted: Wed Dec 14, 2005 12:26 am
thats what my father in law said. so i guess im going to look in to that as well. thanks
 Post subject: Was that the problem?
PostPosted: Thu Dec 15, 2005 7:52 pm
Lets us know if the choke was the problem. I'm curious now. Hope all goes well for you.
:smt023
"Experience is a hard teacher, for she gives the test first, and the lesson afterwards."
1978 Chevy LUV - 2WD - [Work In Progress]
w/1976 1.8L 1815cc Stock Isuzu Motor
http://forums.luvtruck.com/viewtopic.php?t=8843
PostPosted: Thu Dec 15, 2005 8:10 pm
just got the brakes fixed so i'm going to look at the carb tomorrow. but ill let yall know.
PostPosted: Fri Dec 16, 2005 3:28 am
i would go whith the choke is still partially engaged as well. If thats not the case just tune the carb a little and check the timing.
 Post subject: Carb
PostPosted: Fri Dec 16, 2005 10:02 am
I had a Hitachi on mine that was running extremely rich. So rich there was a 1/8" pool of gas laying in the bottom of the intake manifold. I rebuilt it and Permatexed the internal gaskets. Still ran rich. I concluded it had an internal, unfixable leak and replaced the carb with a Weber. Been OK since.
PostPosted: Tue Oct 30, 2007 5:48 pm
My 80 Luv is running on the rich side. Just rich enough to barely miss the Nevada smog test. I replaced the plugs, distributer cap, and air filter. I added a fuel system cleaner to the tank and filled it up with 93 octane to help burn through the old fuel. How do I adjust the fuel mixture on the carb? Also, how do I adjust the idle speed? It wants to quit on me for the 1st 10 minutes in the morning. I figured if I reduced the mixture a smidge and increased the idle a bump, it would start easier in the morning and maybe pass smog.
Emo
PostPosted: Tue Oct 30, 2007 9:33 pm
^^topped^^
PostPosted: Thu Nov 01, 2007 4:20 am
Is your choke working????
PostPosted: Thu Nov 01, 2007 6:07 am
Make sure your choke is working then check your float hight
Pull the air cleaner top off the start the truck when cold and watch the choke blade and see if it is opening all the way.
The engine should be at a fast idle while running and in 3-5 min it will shut down to a normal idle this is of course if every thing is set as it is suppose to be.
Get out your trusty repair manual and do the adjustments then do the check run again.
Also check the float hight as if it is to high you will be running rich.
Make sure there is 12 volts to the choke for proper operation.
PostPosted: Thu Nov 01, 2007 8:24 am
thx, will do.
PostPosted: Thu Nov 01, 2007 11:23 am
PITA Old Fart
And don't expect miracles...because IMHO you are working with one of the worst POS carbs ever made.
PostPosted: Fri Nov 02, 2007 9:07 am
I broke out the trusty fluke meter and measured the voltage. 9.5-11.8 volts, so that's good. I opened up the air filter and cleaned the carb. Turns out the butterfly valve is stuck open and won't close. So now I need a new carb. I guess it is time to figure out how to do the Weber carb swap. :oops:
Still waiting for my Haynes to come in. At that point I'll figure out how to lean it out a little bit.
PostPosted: Fri Nov 02, 2007 3:13 pm
The choke won't close untill you open the throttle a bit.
PostPosted: Fri Nov 02, 2007 10:16 pm
emodx wrote:
Turns out the butterfly valve is stuck open and won't close. So now I need a new carb. .
Dont see why. Just adjust it so its wide open.
Bob.
Users browsing this forum: Baidu [Spider] and 26 guests
