It is currently Fri Jun 19, 2026 3:00 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: fuel millage...
PostPosted: Sat Jun 25, 2005 10:56 am
Wel i just did my fuel millage numbers and im rather impressed. I drove 313 miles at about 75mph (3500rpm on the old tachamometer) and i got 22mpg. Not too bad for the little piggy eh?
PostPosted: Sat Jun 25, 2005 7:24 pm
The best I have gotten is 23mpg.
PostPosted: Mon Jun 27, 2005 3:06 am
u 2 are lucky, i only get 19!, it sorta sucks but montana has bad gas, as soon as i go out of state, its goes up to about 21 even if im at the same elevation
PostPosted: Mon Jun 27, 2005 4:53 am
22 to 23 is about right for me as well.
http://www.purerockradio.net/
PostPosted: Tue Jun 28, 2005 2:45 am
My 79 4x4 runs right about 20-21 city, highway, pretty much anywhere. It also drinks a bit of oil at the same time though.
My 77 2WD runs in the 25 range, and it dips down to 21-22 if its all city driving.
PostPosted: Tue Jun 28, 2005 3:38 am
Swap Specialist Mod
what should i expect from my pup? its got the g200 and a stock carb. im guessin it will prolly get about what theBEAST gets.
neil
PostPosted: Tue Jun 28, 2005 4:24 am
it might be a little different for u farmer, i have a weber on mine and im not to sure its tuned just right, and your not in montana, most of montana has gas of lesser quality compared to most other states, so it does affect our milage, if yours it tuned right and your engine has been striped of all the emisions stuff like the smog pump and all the vacum relays, you should get better then me, but thats just my expearience, im not to sure on the quality of gas in idaho, but i belive its better then montana.
PostPosted: Tue Jun 28, 2005 10:45 am
I get 22-23 in town 26-27 on freeway with a stock 80 4x4
PostPosted: Tue Jul 05, 2005 7:44 pm
LUVTruck.com's Cornholio
For as expensive as Montana's gas is I would think it would be some good stuff. :lol:
With the way I drive, I get about 10mpg in the city or 12 on the highway. 8)
PostPosted: Tue Jul 05, 2005 9:22 pm
trust me, montana's gas sucks, diesel and all, i agree, montana has expensive gas but it's not that great, every one i have ever talked to that travels out of montana alot agrees with me, our gas milage goes up when you get out of state, i dont know what it is with out gas its just not that great, maby they try to make it burn cleaner of somthin but out gas milage sucks, maby its time for me to put a trooper 5spd im my truck, maby that will help a little, any one got an old trooper they wanna part with the trany?
PostPosted: Tue Jul 05, 2005 10:08 pm
hey beast does a trooper tranny bolt directly up to the 1.8 or is there modification involved
PostPosted: Tue Jul 05, 2005 10:13 pm
i belive it is a direct bolt up, i have read some other threads of someone acualy doin it, but you have to have custom drive shafts made, and you have to use the trooper cross member and transfer case
PostPosted: Tue Jul 05, 2005 10:18 pm
here it the tread of someone doin this conversion
http://forums.luvtruck.com/viewtopic.php?t=2207
PostPosted: Thu Jul 07, 2005 10:17 pm
thanks thinkin about putting a 5 spd in for better gas miles.
PostPosted: Sun Jul 17, 2005 4:44 pm
well just to make you all feel good my lov get between 4 to 6 miles per gal and at the prices now i wont drive it to much. :? if theres a meet over 50 miles i plan on trailering to the meet.. its still apart for i found out rods were shot so waiting on new ones to come in now. hopefully running in a few weeks :wink:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Sun Jul 17, 2005 4:52 pm
Luvtruck.com Wookie
that's how it goes for me........i have to put premie in my rig so i'm paying $3 a gallon too.
time to quit slacking and get that new rear-end in........ :smt033
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Aug 04, 2005 9:06 am
back a year ago while i was still driving it i was getting 26mpg on the freeway @70mph
PostPosted: Sat Sep 10, 2005 10:22 pm
I get any were between 25 and 36 sines its got a new motor and carb
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Sep 21, 2005 2:44 am
Well was pretty disapointed in the mileage (if you wanna call it even that) that the luv was gettin. Turns out, I has the vac. lines wrong on the carb.--holley 650--to the secondaries, as soon as I hit the gas, it was dumping fuel to all 4 barrels :evil: Rerouted some lines and wudda you know, I can now drive around for a day without hittin the station more then once.
PostPosted: Wed Sep 21, 2005 9:36 am
My gas milage just went up a whole bunch too. Its amazing what a non slipping tranny will do. 8) Its also a whole lot faster than before.
