It is currently Tue May 26, 2026 5:07 am
PostPosted: Sun Sep 02, 2012 5:13 pm
ok i tried this afternoon to drop that 350 small block into my 1979 chevy luv and i could get the trans mounts to line up so i could weld the motor mounts into place any suggestions
PostPosted: Sun Sep 02, 2012 8:13 pm
where is it hanging up? transmission? engine ? oil pan? crossmember in the way?
PostPosted: Sun Sep 02, 2012 8:36 pm
Idk it seemed like The transmission was too long when I got the motor to where it look just right the transmission was sitting on the oil pan. And the right header comes into pieces and I had to take the little piece off so I could angle the motor in haha
PostPosted: Sun Sep 02, 2012 8:55 pm
What trans are you using?
PostPosted: Sun Sep 02, 2012 9:10 pm
Turbo 350 short tail
PostPosted: Sun Sep 02, 2012 10:01 pm
That trans isn't too long. I've had an NV3500 in mine and now a 700R4 and they are both longer than the TH350.
I have to admit, I'm stumped. I have no idea what is going on here.
PostPosted: Mon Sep 03, 2012 9:31 am
Here is a pic of mine with the short 350
PostPosted: Mon Sep 03, 2012 9:40 am
I haven't installed a v8 in a luv yet, but from what I'm understanding from your post id your trying to mount the trans in gthe stock location of the luvs trans, if so that will not work and you will have to make a new trans mount depending on how far back or forward you want your engine installed....but that's what I got from your question, sorry if I missed understand.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Mon Sep 03, 2012 10:35 am
Luvtrkr can u post were ur motor mounts ended up plz and thank u
PostPosted: Mon Sep 03, 2012 2:31 pm
I believe I have Hooker mounts.
Driver side
Passenger side
PostPosted: Wed Sep 05, 2012 10:37 pm
Yes you have Hooker and the TH350 trans cushion bolts should be approx 6" forward of the crossmember.
PostPosted: Thu Sep 06, 2012 3:26 am
Hang in there . It will fit with a th350 . Measure twice cut once . You can always remove more metal . it is alot harder to put it back after its cut out . Here is my factory mount modified for a th350 .
Just for grins homemaade motor mount also , these use 67-69 Camaro rubber pads and worked with Hooker block huggers and Hooker conversion headers
PostPosted: Thu Sep 06, 2012 7:45 pm
thank you so mucho(much) haha i'm learning Spanish in school now haha... i hate it :/....... so did any of y'all modify the front cross member like cut a slot in it so the pulley on the balencer will fit
PostPosted: Thu Sep 06, 2012 9:52 pm
My current Yellow one has a notched crossmember and the grat 76' had one . The Blue 78 and the orange 75' im building don't have balancer clearence cut outs . The belt is tight without the cut out , but will work .
PostPosted: Thu Sep 06, 2012 9:55 pm
If you run a short style water pump, the pulley will barely clear the front cross member.
Users browsing this forum: Bing [Bot] and 28 guests
