It is currently Mon May 25, 2026 4:23 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: Ls1 77 luv how two
PostPosted: Tue Oct 25, 2011 8:59 pm
I no people might see im new to this site but im not new to luvs .iv had 4 luvs and one iv had for 9 years iv done a lot, and seen a lot. But its time for a make over ... And I will need a little help (web site and stuf) 1977 chevy luv.
5.7 ls1 auto trans . What stock wires do I keep( altinator starter)?
Im a lowered truck guy so I was thinking s10 2" drop spindels I saw a kit on here and coilovers but I want adjustables so I can lowerer it as I see fit . (Im giting rid of t-bars )
Rear end s10 xtream(posi) or 9" if money is still ok ... 52" is what I think the width is
I have 15x8 front and 15x10.5 rear et slots.. Looking to update to 18x8 front and 20x10 rear( ss craigers I think)
[b][/b]
 Post subject: Re: Ls1 77 luv how two
PostPosted: Wed Oct 26, 2011 2:23 pm
Answering your question about wiring? You can keep the stock water temp guage wire, the oil pressure sending wire, but since you will probably be using a one wire alternator, remove all the voltage reg wiring and use one HD wire from the starter hot wire to the new alternator If you still have the stock wiring to the fuel pump, you will have to run a new wire to it, or find the wire coming off the fuel pump relay that is located by the battery under a cover and direct wire the fuel pump to a keyed source.
I have mixed answers to powering the starter solenoid because some guys have simply connected their Luv's stock solenoid wire to the small wire on the new starter. I have not had that much luck, seems I have always had to install a relay that supplies a better current flow to the starter. Also I install a relay to supply the power to the new ignition, bigger wires, but again this is up to the installer. Good luck, I am sure you will get lots of suggestions from the good guys on here!
dp
PostPosted: Wed Oct 26, 2011 5:17 pm
Thank you 4 the info.. And il probly run a fuel cell
PostPosted: Wed Oct 26, 2011 9:39 pm
I have a 76 and i used a CS130 alt which is the same style as your LS1 will have . I suggest tracking out the wire and using the factory alt light in the dash to excite the alternator , adding a resister in parallel just incase the bulb goes out the alt will continue charging and not burn up the alt . Also the factory power lead to charge and the factory voltage sensing wire to signal how many amps the alt needs to put out . The three wire alt set up works much better or GM would use all 1 wire set ups .
I have had good luck using the factory wiring attached to the V8 starter on both trucks .
Next is the LS series in a Luv . I have not done this , but it appears they require extensive mods to fit ( hoping Wicked Mayham will chime in ) .
When your post count gets high enough post a picture or 2 of your trucks .
PostPosted: Wed Oct 26, 2011 9:46 pm
i would send wicked a pm and look at his build thread...
PostPosted: Wed Oct 26, 2011 10:11 pm
I too am having luck with this set up, 3 wire and stock wires to the battery.
PostPosted: Thu Oct 27, 2011 8:17 am
Ok , i forgot to mention my old truck was a 1 wire 10 si / 12 si style . It worked , but i also went to the 3 wire set up with the 10 SI which for me worked alot better . At that time i has a big electric fan that was a power hog . The 2 wire seemed to "ramp up to the load better .
Basically SI style or CS style will work . I think the cadillac CS140 is 144 amps . At that rate you might run into problems with stock wiring . If you have a draw that is over 100 amps you need costom wiring anyway .
PostPosted: Thu Dec 01, 2011 1:18 am
Ok im back sorry it took so long. I sold my rsx but then git a chevy monza put a mildly mean 350 in it but its runing so back to the luv . Im one a ls1 hunt
PostPosted: Wed Dec 21, 2011 10:34 pm
I got my motor trany !
PostPosted: Wed Dec 28, 2011 5:39 pm
Im at a loss! Its been 10 years since iv work on my pore luv im puting ls1 in it and doing a wire tuck snd deleteing luv wires im not going to use . What r the two relays on passenger side by window wash? I deleated stareter wires and 3 ofthim went there can i delete it all toghter
PostPosted: Wed Dec 28, 2011 6:04 pm
ceaning
File comment: Cleaning
PostPosted: Wed Dec 28, 2011 6:06 pm
Working on lowering
PostPosted: Wed Dec 28, 2011 7:31 pm
My baby
PostPosted: Wed Dec 28, 2011 7:36 pm
77 luv
PostPosted: Thu Jan 05, 2012 9:28 pm
Mock up
File comment: Mock up
PostPosted: Thu Jan 05, 2012 9:30 pm
Fit grate ... Batery tray mite no clear header
PostPosted: Fri Jan 06, 2012 8:51 pm
Keep us posted with the build. I'm going to be doing a 5.3 with a turbo in my 77 soon. It will be nice to know what issues or anything with the swap. Are you keeping the ls1 stock or doing some upgrades?
PostPosted: Sat Jan 07, 2012 9:31 pm
Sweet ok so i got a 5.3 4l60e so we can help one another im changing to ls1 waterpump and crank pully there closer in so i have radiator clearance . I went with ls1 intake 4 hood clearance. And it looks cool :) i ordered from o'rielly a ls1 to 350 kit... And i have my old luv 350 kit so im hoping 4 bolt in
PostPosted: Sun Jan 15, 2012 5:56 pm
In
PostPosted: Tue Mar 06, 2012 6:48 pm
Trany was easy
Users browsing this forum: Bing [Bot] and 21 guests
