It is currently Thu Feb 19, 2026 10:10 am
PostPosted: Mon May 10, 2010 11:15 pm
im having trouble finding a gasket/seal for the differential where the driveshaft yoke is.
anyone have the correct name? its currently leaking and before i lose the rear end, i need to get it replaced...
PostPosted: Mon May 10, 2010 11:35 pm
try pinion seal autozone Part Number: 474133
or if you mean the big round one with i think 10 bolt holes like this? Axle Housing Gasket Part Number: RDS55084
PostPosted: Tue May 11, 2010 2:55 am
not the large main seal for the housing, just where the yoke meets the actuall differential.
i was looking through my book and was trying to find an exact procedure for it's replacement, but havnt come up with anything. a little help?
PostPosted: Tue May 11, 2010 10:20 am
Are you talking about Pinion Oil Seal. You need to take the yoke off to replace it, and never reuse the old nut, you need to get a new nut and it has to be torque down checked with a inch pound torque wrench, not a foot pound torque wrench to get proper preload. Hope this link helps a little- http://www2.dana.com/pdf/AXSM-8663.PDF
PostPosted: Tue May 11, 2010 5:40 pm
Actually you can re-use the nut IF you go about it correctly: the nut has been staked to the threads to keep it from backing off, so you need to run a tap through the nut to clean the dent out of the threads, then also run a die over the pinion shaft threads to clean them up, afterwards the torque is not effected by the deformed threads.
I have had good luck torquing the nut to 100 ft-lbs with the p-brake on, wheels chocked, this seems to get it tight enough without getting it too tight and collapsing the crush sleeve too far. I like to use a little thread locker and be sure to stake the nut threads to the shaft.
Timken # 474133 for the seal.
Users browsing this forum: Google [Bot] and 53 guests
