It is currently Tue May 26, 2026 3:26 am
Post new topic Reply to topic  [ 89 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Sun Apr 27, 2008 12:21 am
just got my motor and working on the swap. going to use ls1 swap mounts from s10v8.com and hopefully trans am factory ls1 manifolds trucks wont fit. th350 trans 3500 stall. also going for carbed set up instead of efi! Still deciding on rear end.
I think this will be the first luv ls series engine swap???? factory specs on my motor are 345 hp and 380 tq factory. carb intake free exhaust should jump it to 400 hp easily lol in my 2500 pd truck WOW :lol: :lol: :lol:
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 10:37 am
subscribed, what oil pan are you using, how low does it hang under the crossmember if any?
PostPosted: Sun Apr 27, 2008 11:00 am
I had to take crossmember out to put it in. I still havent finished my motor mounts but the oil pan that came with it(truck oil pan) fits nicely about 1/4 inch maybe less behind crossmember.
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 12:28 pm
Good web site. I have been on it a long time, I thought I was going to do a S10 before I got my Luv.,.. A lot of the things they do should work on a Luv with a few mods, if needed.
PostPosted: Sun Apr 27, 2008 1:14 pm
thats cool....
Im not along far enough to put in a motor and trans.... but I kinda wanted to do a 4.8 or 5.3.... im glad to hear someone going with an LS engine. I wanted to be able to make mine somewhere between a daily and weekend driver.
Of course if gas keeps going higher and I dont get a motorcycle soon then I will probably end up with a 4.3 instead.... lol
PostPosted: Sun Apr 27, 2008 3:06 pm
yeah my buddy is doing a 5.3l in his 89 s10 but he is buying parts like the motor mounts that already work and i am adapting them to my luv. My main problem now is exhaust. I also need coilovers anyone have any for sale??
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 3:07 pm
oh and oil pan is probably gonna hang about 2-3 inches.
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 5:43 pm
Thats about how far mine sits on my S10, I don't want to lower it because of that, but I've heard that the oil pan for an H3 will set about an inch under the crossmember, if clearance is a problem ( like if you intend to lower it) you might go with that pan. or maybe an ls2 oil pan from a 05 up vette. how much clearance do you have from the bottom of the pan to the crossmember?
PostPosted: Sun Apr 27, 2008 6:39 pm
from crossmember to bottom of oil pan is 2-3 inches and sits about 1/4-1/2 inch width from crossmember. I will be fine for now no plans on lowering it but if i do i will switch to a different pan.
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 9:10 pm
i was gonna just make somethin to cruise around with decent power like my old luv. the red one in my pic but decided i wanted to rule the roads around here!lol i dnt care how much gas is! Im young and i like to go fast.lol SHAKE AND BAKE- putting it on the back window haha
6.0l ls1 swap th350
PostPosted: Thu May 01, 2008 10:22 am
I took the cab off last night. gonna buy some coilovers soon and make removable crossmember. Probably gonna cut firewall and set it in for some clearance.
6.0l ls1 swap th350
PostPosted: Fri May 02, 2008 11:50 am
more pics
6.0l ls1 swap th350
PostPosted: Fri May 02, 2008 4:09 pm
mine ALMOST looks like that :ebiggrin
PostPosted: Fri May 02, 2008 10:48 pm
haha yeah i see that pic on the right beside the silverado. at first when i saw your posta i was like its just a frame then i realized it was a luv truck frame :lol: I cut my crossmember out and torsion bars and grided on the frame for about 3 hrs.
6.0l ls1 swap th350
PostPosted: Sun May 18, 2008 7:52 pm
well i took all brake hardware off and spindles etc. I am going the cheap route with s10 conversion just got the ball joints for now. I half way did the frame and painted it with one coat for now. hopefully coilovers and front end parts in a couple of weeks so i can sit the motor and tranny in to make my crossmember.
6.0l ls1 swap th350
PostPosted: Sun May 18, 2008 8:09 pm
this is what it looked like easter!lol
6.0l ls1 swap th350
PostPosted: Mon May 19, 2008 10:14 am
I'm looking forward to seeing this come together, this is gonna' be sweet! Keep it up, looks good so far. 8)
PostPosted: Mon May 19, 2008 11:35 am
thanks man!
6.0l ls1 swap th350
PostPosted: Mon May 19, 2008 3:40 pm
what did you coat it with?
I went with some paint on bedliner, and some of the same stuff in a spray can to get the hard to reach areas like in the body mounts.
PostPosted: Tue May 20, 2008 3:54 pm
well i got filler tractor primer from tractor supply in spray can then i got black tractor paint for my spray gun
6.0l ls1 swap th350
