It is currently Wed Mar 18, 2026 7:03 am
 Post subject: MegaSquirt!
PostPosted: Thu Nov 01, 2007 2:08 pm
I have decided after much thought to go ahead and run a Stand Alone EFI, i thought about the impulse intake, and about the offy intake with the fat weber, but after all my searching i think that Fuel injection is for me (I'm young and thats what we do now) tune with a computer instead of a screw driver... I was jsut wondering what peoples thoughts and input may be, if i can get this to run properly then im going to to a complete write up on the whole thing for this site, and hopefull pave the way for a whole new era of non-impulse EFI Luv Trucks... Also I'm curious about running the Electronic Ignition, I have read the write ups that are here, and have seena couple angles to go at it, so my choice is drive 50-100 miles away to find a distributor, or order a pertronix and bolt it in, so basically...
-=Modded intake manifold=-
-Injector ports
-Adapted throttle body
-Fuel rail w/ regulator
-Inline high pressure fuel pump
-02 sensor (in stock exhaust manifold)
Am I missing anything???
-Dustinicus
PostPosted: Sun Nov 04, 2007 11:46 am
Sensors - crankshaft or cam position
O2 sensor
coolent temp
throttle position
manifold air pressure .
Mega squirt is a good system and very flexible . I am learning about this also and one of the engineers at work builds them from scratch . This can and will work . Keep us posted as you go .
PostPosted: Mon Nov 05, 2007 9:40 am
I found that instead of modding my dist. i can just get an EDIS system, and i like the sound of that, besides where is the fun of modding an engine if when you open the hood people dont say WTF? hows it getting spark, and where is the distributor... lol... but another thing is what do you know about the later isuzu 2.6l or 2.3l intakes/engines? i heard the manifolds will interchange, but there not a straight alignment.. do you know anyone that has pics mabye
Thanks
Dustinicus
PostPosted: Wed Nov 07, 2007 3:36 am
If you decide to go with Impulse fuel injection, I have an intake/FI, and distributor from an 85. Was told it was working, before the engine was removed. No computer with it.
PostPosted: Wed Nov 07, 2007 5:13 am
I'm using the ford EDIS ignition system I did alot of research and found it to be far superior.. and as for the intake i got an offer for one so we'll see.. ill send you a pm
-Dustinicus
PostPosted: Wed Nov 07, 2007 8:49 pm
I'm sure mega squirt will work with these parts .
PostPosted: Thu Nov 08, 2007 9:17 am
un doubtedly it will work tis a really flexible system... miht you have any other input that could be of use it would be appreciated
-Dustinicus
