It is currently Sun Apr 05, 2026 5:06 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 328 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 17  Next
PostPosted: Mon Mar 12, 2007 11:43 am
2 days later. Plates were sent as said?
1977 Chevy Luv
350/TH350
PostPosted: Wed Mar 14, 2007 10:51 am
I am at my wits end.
1977 Chevy Luv
350/TH350
PostPosted: Wed Mar 14, 2007 10:56 am
8O
PostPosted: Wed Mar 14, 2007 1:50 pm
I am not the master mechanic some of you guys are. This s-10 conversion is not for the amateur mechanic in my opinion. The toughest part of it all is (a)fabricating the plates and (b) positioning the lower ball joint in the exact right spot so that your s-10 spindle sits on the balljoint correctly, getting free range of motion. If it sits to far in, you're binding.
So I get these plates made. Plasma cutter did a horrible job but looks are not my concern. I put them on and drill the mounting holes. 2nd I have to guesstamate the ball joint placement based on the pictures this other guys has done. It apeared I placed them fine but whe I put the spindle down it's obvious I've put it way too deep in the 'V' and I am unable to get much movemnt from them.
So I take the spindle off and grind it down, essencially weakening it. I have taken enough off of it that I really dont trust its integrity anymore. So much for the $75 junkyard s-10 spindles. To make matters worse- when getting the lower stock ball joint off I think I remember anniliating the lower stock mount so now to do the Aerospace $600 set up I am missing 1 of those.
All of this could have went so much easier if this fella above would of sent me the plates he designed and knows work as he said he would countless times. Oh well.
ok, I now realize I'm just ranting because I am frustrated and its getting hot in Arizona.
[/thread]
Pictures of the damage.
I shoulda stuck with the electdic go ped of my daughters in the background!
1977 Chevy Luv
350/TH350
PostPosted: Wed Mar 14, 2007 3:02 pm
if you whated to lower it just put the plates on top of the control arm.
you did a good jod thare Hyperwrx looks can be fixxed later.
PostPosted: Wed Mar 14, 2007 3:20 pm
Lower it?
The process converts it from a 6 bolt hub to a 5 bolt hub.
1977 Chevy Luv
350/TH350
PostPosted: Wed Mar 14, 2007 7:51 pm
Wow Hyper. Sounds tough. I give up on my 5 lug conversion kit. I am sticking to the 6 lugs in front until something promising comes along. I am no master either but I can figure most anything out with enough time.
What about the other conversion on here with the toyo discs. can we do them easier.
PostPosted: Wed Mar 14, 2007 8:17 pm
No idea- link me to that thread please.
1977 Chevy Luv
350/TH350
PostPosted: Wed Mar 14, 2007 9:11 pm
Hang in there hyper . There is no easy/ cheap conversion . The cheaper the harder it seems . T.J. white's toyota rotor conversion is no cake walk or bolt on , but i'm proof it works . I think i'm officially the second one to do it. I will probably put the areospace kit on down the road when funds permit . I lost 30 # off the truck too .
PostPosted: Wed Mar 14, 2007 10:09 pm
You should have done received it hyper, I don't have the tracking number with me it is in the desk in the office at the shop. Hotrod80 did your package arrive already? How about you Rick? I will check with it in the morning. I have no idea what is going on. I have however got the go ahead to have 10 sets cut out for me for those whom may still be interested.
PostPosted: Wed Mar 14, 2007 10:14 pm
I got my package . Thanks
PostPosted: Wed Mar 14, 2007 10:20 pm
Thats good to hear.... Btw will that work or do I need to send you the one out of my mikado... I had already put the one out of my mikado in storage and couldn't find it so I sent the one off my 4x4 parts truck.
PostPosted: Wed Mar 14, 2007 10:51 pm
I still want a set of plates when ever you get around to them Shawn. Thanks
PostPosted: Wed Mar 14, 2007 10:53 pm
It is all systems go I will least be making a additional 10 sets not counting the 3 1/2 sets I have made. Weather I sell them or convert a fleet of Luv's myself they will be used :lol:
PostPosted: Thu Mar 15, 2007 6:11 am
So how much for the set of plates. Still have my 88 s-10 with the stuff I need.
PostPosted: Thu Mar 15, 2007 8:24 am
I will give youa big kahonies for trying this.. 8) You got bigger ones than I do.
Richard
PostPosted: Thu Mar 15, 2007 9:02 am
I told you I didnt get the first package and in time the postal service returned it to you for whatever reason. Once again I am telling you, no package has arrived. I think you are sending it to the wrong address.
Scott Francom
4650 S. Stallion Dr.
Gilbert, AZ 85297
Either that or this is some crewl joke with the intention of having me throw all my tools across the garage in frustation.
1977 Chevy Luv
350/TH350
PostPosted: Thu Mar 15, 2007 5:54 pm
What are you getting for a set of those plates?
 Post subject: ball joints
PostPosted: Fri Mar 16, 2007 4:23 am
I have not been on in a long time. it seems I opened a pandora's box with my comments about this setup and no one saw that what I was saying. We were on parallel lines and never going to meet. I must go by the initial pics that I saw.......I say "initial pics" the views that I looked at showed no flange resisting a pull out. Hyperwrx has some good pics that show how the everything mates up. Opps another pandoras box. I did not say the first pics of this discussion were no good.......I am saying I did not see clearly the flange on the bottom mating surface of the plate. hyperwrx shows a good pic, pressed in from the bottom, shows the flange on the ball joint mating to the plate. This is safe and I agree with this. the plate being bolted to the lower arm is no different that the luv ball joint being bolted on. I agree with these pics as shown.
Let me xray you, you will feel better.
PostPosted: Fri Mar 16, 2007 4:40 pm
8O I feel like such a tard man. It has been all my fault from the get go and I didn't even know it, Both times I had sent the packages to
Scott Francom
4650 Stallion Dr.
Dilbert, AZ 85297
and it turns out there isn't a Dilbert, AZ. :oops: I am really sorry I dunno if it was the way I copied it the 1st time or word association. Seems like someone at the post office would have picked up on that. Man am I embarrassed. I am totally sorry for all the frustration I have put ya through. :oops:
You must have never checked out my list of pics of Page 5 of this tread.
This pic from mock up should have shown how the ball joint it's self is pressed it.
As far as cost of plates I will have to wait and see what the finial figure is at the machine shop to see how much I can let them go for.
