It is currently Mon Jun 29, 2026 10:00 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: just got weber need help
PostPosted: Thu Mar 08, 2007 6:20 pm
can i put it on it looks like the linkage was still on it. but i dont know exactly what im looking for. i dont want to take the hitachi off if i cant get this one to work. or can i use whats on the factory carb to get it to work
billy
PostPosted: Thu Mar 08, 2007 9:16 pm
my first weber i took off the linkage from the luv carb and put it on the weber ... worked fine and my son still has it on his luv now, been about 3 years and no problems
PostPosted: Thu Mar 08, 2007 9:44 pm
so if i take the linkage off the hitachi it will fit on the weber no problem? it looks like it already has some type of linkage on it, maybe for a different vehicle or something. maybe that one will work, like i said im new to the carb thing. thanks ctmandu, do you happen to have a pic of what the linkage looks like on the weber or the linkage period, again thanks.
PostPosted: Thu Mar 08, 2007 10:57 pm
no i don't ... i have pics but not with the linkage ...if you take the linkage off the weber it should have a rectangle cut out the will fit the weber ..
PostPosted: Thu Mar 08, 2007 11:17 pm
I pretty much hacked up the stock linkage thing and welded on a bracket i made to put it in the right spot. It has worked so far. Bout a year.
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Fri Mar 09, 2007 6:53 pm
ok i got it on but my throttle cable is real sloppy, how do i adjust it to tighten it up?
thanks
billy
PostPosted: Fri Mar 09, 2007 9:33 pm
need to make a bracket like this
PostPosted: Fri Mar 09, 2007 9:56 pm
i see can i pick one up at a auto part store or does any other vehicle have one that will fit?
PostPosted: Fri Mar 09, 2007 10:55 pm
you can buy them here other wise the stores wont carry them unless you have a speed shop around and they might
PostPosted: Sat Mar 10, 2007 8:17 pm
thanks ctmandu i made one. its not as pretty as yours but it does the trick. thanks for all the help with this, now all i have to do is get it tuned right. any ideas.
PostPosted: Sat Mar 10, 2007 9:39 pm
PITA Old Fart
Warm up your engine to operating temperature, then set your idle at 800-900 rpm's.
Now turn in the fuel/air adjustment screw untill it runs rough, then back it out counting your turns untill it runs rough again. Turn it back in exactly 1/2 of the amount of turns you just used to turn it out, and it is set.
All weber 32/36's are set halfway between the lean rough idle and the rich rough idle at normal operating temperature and at normal idle rpm's.
Pretty simple, huh?
PostPosted: Sat Mar 10, 2007 10:03 pm
Hmmmmmm, guess Im biddin against ya on the grille. :twisted:
PostPosted: Sat Mar 10, 2007 10:13 pm
that grill on ebay only has the one bend in the middle not three like it should, see mine below with the three
PostPosted: Sun Mar 11, 2007 3:05 am
looks like 3 to me.
PostPosted: Sun Mar 11, 2007 5:13 pm
Beats me. The guy said it came off his 79 luv. probably a straight custom grille.
PostPosted: Mon Mar 12, 2007 6:38 am
ok my carb is dieseling when i cut it off. do i need to open my air mixture screw more or close it alittle more? its almost like its running sluggish.
PostPosted: Mon Mar 12, 2007 9:03 am
Are you sure it's the carb? Is it dieseling at shutdown? If so it might be timing more than carb...
Here's some more info on setup and adjustment:
http://www.carburetion.com/Weber/adjust.htm
http://www.redlineweber.com/html/Tech/3 ... unning.htm
http://www.euronet.nl/~wilaben/adjusting_weber.html
Good luck!
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Tue Mar 13, 2007 12:11 am
PITA Old Fart
If you go into the free stuff on this site's info download page, there is a complete file on all things weber that I personally donated there. You can download it, open it up, and it contains a lot of .pdf files (Adobe acrobat reader...if you don't already have it, you can download it for free) that list part #'s, adjustments, fault diagnosis, troubleshooting, diagrams, pictures, rebuilding/repair instructions, etc. for every model of every weber carb made.
While you are at it, check out all of the other great freebies there too.
BTW...if it's deiseling when you turn it off, your timing is set wrong, just like the man said.
PostPosted: Tue Mar 13, 2007 6:31 am
when I put my weber on it would diesel on shut down too. But my idle screw was in too far. I gave it a little bit to slow it down and it fixed it.
PostPosted: Tue Mar 13, 2007 7:47 am
ill try that if it dont work i guess ill have to look into my timing.
