It is currently Mon Jun 08, 2026 7:52 pm
 Post subject: fuel pump
PostPosted: Thu Feb 22, 2007 9:14 pm
does any one know what the fuel pump pressure should be on 1981 1.8
reason asking is been though 2 in line cheap pumps and trying to see if it not putting out enough or to much
92 gmc on 35/12.50/15
81 luv on 31/10.50/15
PostPosted: Fri Feb 23, 2007 8:45 pm
On a 78 the fuel pressure is 3.56 psi. It maybe the same on a 81.
PostPosted: Sat Feb 24, 2007 7:16 am
kool thanks thats around what im getting at the carb i think my pick up tube in the tank is what is casueing the issuse i belive it is clog and thats causeing the pumps to go
PostPosted: Sat Feb 24, 2007 1:41 pm
When I got my truck it had a cheap aftermarket pump under the hood. It had to go because it was to load. Bought a napa (carter brand) fuel pump on ebay (new for $30) and put it back in regular spot. Put on a weber and a fuel regulator (set at 2.5 psi) with no more problems.
