It is currently Tue May 26, 2026 12:56 am
 Post subject: Mounting a rear bumper
PostPosted: Fri Feb 09, 2007 6:58 pm
I found myself a good used rear bumper, and was hoping someone might know offhand what nuts & bolts I'd need to mount it.
That and what bolts to use to mount a tow hitch - I'll see if I can get pics of both parts this weekend, but don't know if I'll be home during daylight. 8O
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Fri Feb 09, 2007 11:02 pm
Just be sure to get a high-grade bolt with a hardness rating of seven or eight. I forgot the ratings to be honest, and just ask the hardware store. Especially if you're hauling your teardrop; you don't want the whole bumper coming off, NO WAY!!!
The harder the bolt, the more it costs. :D
Just whatever fits the hole.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sat Feb 10, 2007 5:25 am
I think they are somewhere around a 12mm bolt, but I don't remember. Once you figure out the size (buy a variety of cheapo bolts and test fit, then get the hardened ones) you might want to get a tap the same size and clean out the holes. Then put some anti-sieze on the new bolts when you install. They are exposed to water and crud a lot under the truck so they like to rust in place, and the threads are inside the frame so they are very hard to fix if they strip out.
Oh yeah, there are six bolt holes under ther, three per side.
PostPosted: Sat Feb 10, 2007 9:25 am
Yes use grade 8 or harder bolt not necessarily to hold the bumper on but the harder the bolt the less chance of corrosion.
PostPosted: Sat Feb 10, 2007 12:23 pm
gah sum idiot welded my rear bumper on...
so now i gotta cut it
people are very dumb sum times..
PostPosted: Sat Feb 10, 2007 5:22 pm
PITA Old Fart
I suspected that was the case but I didn't want to say anything to depress you...lol.
Darn near every every one I've ever seen is. Some people are just too lazy to bolt them in I guess.
Hopefully they didn't weld over the bolt holes or screw up the nuts to bolt them into real bad, and it won't be a real pain to deal with.
Good luck.
PostPosted: Sun Mar 04, 2007 1:23 am
OK - here's what bolts are needed from a local hardware store...
4 G8 7/16"x1" bolts
4 G8 7/16" nuts
4 Zinc-coated 7/16" lockwashers
8 G8 7/16" washers
2 G8 3/8"x1" bolts
2 G8 3/8" nuts
2 Zinc-coated 3/8" lockwashers
4 G8 3/8" washers
Total cost including two sets of spare 7/16" hardware: Less than $15.
Pictures to follow shortly.
PostPosted: Sun Mar 04, 2007 1:49 am
I started out with the bumper sitting on a box behind the truck in about the right spot. Here it is, with the nuts & bolts on it ready for insertion.
Then I lifted it into place and held it up with my knees while getting things started. At which point I realized thet the 7/16" bolts are a smidge to big for the upper holes... I got 4 bolts in the lower holes and all tightened up, and bought the extra two 3/8" bolts on the way home. Those will go in first thing tomorrow morning.
In the mean time, here's how it ended up looking:
PostPosted: Sun Mar 04, 2007 11:34 am
nice...looks 10 times better then the bumpers i see around on the luvs here
PostPosted: Sun Mar 04, 2007 12:07 pm
Glad you like it. ;)
It has a few fresh coats of Rustoleum on it to make it shiny, I went over it wit a wire brush in my drill before spraying it - had a little surface rust on the frame bars and the back. Other than that the original paint was just a little faded.
We'll see how the Rustoleum holds up to general abuse. :)
Mainly wanted to follow up so that others could get the right bolts ahead of time, and not have to waste the time test-fitting - that thing is kinda heavy and hard to hold in place while sitting on the cold cold ground.
 Post subject: Nice Bumper
PostPosted: Sun Mar 04, 2007 3:19 pm
Hey Stephen, good job! I wonder did you get high-grade bolts?
You might throw a clear coat on that bumper to make it last longer.
Image Image
PostPosted: Sun Mar 04, 2007 5:30 pm
Bolts, nuts & washers all Grade 8 (G8 in the list above). But the lock washers are just zinc coated.
Re clearcoat... eh, it's just a work truck... ;)
 Post subject: Bolt grade
PostPosted: Sun Mar 04, 2007 5:32 pm
Sorry Stephen, I wasn't reading closely. Good job. :)
Image Image
PostPosted: Tue Mar 06, 2007 4:26 pm
Wow! Nice rear bumper!!!! I have been looking for one like that for some time now.... :o
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
PostPosted: Tue Mar 06, 2007 4:45 pm
Really, I will have to see if I still have mine at my dads house up in Wyoming, WHICH I just happen to be going to tomorrow. Do you ever make it to Colorado???
PostPosted: Wed Mar 07, 2007 1:33 pm
Cool! Keep me posted Tilted! Hardly ever make it to Colorado.....I guess shipping will be the only option for me.
PostPosted: Mon Apr 02, 2007 9:37 pm
Thanks much for posting the bolts needed for this. The bumper I got from ctmandu yesterday is on today becuase of it! Not quite as nice as yours, but then, neither is the truck :lol:
PostPosted: Sat Apr 07, 2007 9:55 am
You should see it in person.... the pictures are a little misleading... ;)
PostPosted: Sat Apr 07, 2007 1:15 pm
It looks good Stephen.
You don't see too many straight front or rear bumpers on these trucks. I don't know what it was about these LUVS... people that bought them liked to hit things I guess. :roll:
Users browsing this forum: Baidu [Spider], Bing [Bot] and 18 guests
