It is currently Sat Jun 13, 2026 7:05 am
 Post subject: 2 piece luv
PostPosted: Fri Apr 18, 2003 11:14 pm
I literally broke my luv in 2 pieces today! I was trying to pull up a shrub out of the ground. Needless to say the very rusted frame buckled and gave way. I think I'm going to cry. No I wont I'm allready looking for a donor body to put 4 years worth of new parts on it!
Power
PostPosted: Fri Apr 18, 2003 11:52 pm
Duuude...
That sucks.
PostPosted: Sat Apr 19, 2003 12:11 am
sounds about like what i did to my 81 :(
get the welder and 2" angle iron out
PostPosted: Sat Apr 19, 2003 7:46 am
that really sucks. farewell luv :cry:
PostPosted: Sat Apr 19, 2003 8:10 am
What year Luv was it? Im wondering if certain year trucks are more prone to frame failures. May be the factory got ahold of bad material for awhile and it's only affecting a set number of trucks in the production order? Or is my brain hemmoraging thinking of crazy stuff like this?
 Post subject: frames
PostPosted: Sat Apr 19, 2003 9:03 am
dude .............I got 2 frames 50 bucks come get one and put your luv together.
PostPosted: Sat Apr 19, 2003 9:18 am
OG Lifer
I have holes so big in my frame now, o can put my whole hand through it.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sun Apr 20, 2003 7:29 am
I think it is a requirement in Tn. that a LUV must severely rusted out, because I've never seen a healthy one in TN.! And it was a 80 4X4. I got out bid by 5$ on ebay on a 80 4X4 with a dead motor only 20 mi from my house...grrrrrr
Power
PostPosted: Sun Apr 20, 2003 12:16 pm
Do they use salt on the roads in Tn. in the winter? Boy I sure am glad they do not use salt out here. That crap tears everthing up. They do use a deicer, which is a salt water mix, that will dull your aluminium wheels, but is not near as corrosive.
PostPosted: Sun Apr 20, 2003 5:51 pm
Must be the 80 4x4's, my frame is rusted on the bottom above the rear end, and the side is (was, I cut the 8 inch bad spot out) rusted behind the crossmemeber behidn the one the tranny bolts to.
PostPosted: Mon Apr 21, 2003 5:06 am
they use salt in Knoxville or maybe some of the northern cities....not in Chattanooga though. my frame is good. :D
hate to hear about the frame though.... :(
hope you find one!
03Cobra
