It is currently Thu Apr 09, 2026 5:26 pm
 Post subject: NO SPARK!!!
PostPosted: Fri Feb 02, 2007 3:05 pm
hey guys im not getting spark at the coil any ideas the fuel pump is wired around the relay? ive heard it fire but it will not keep goin lol.
PostPosted: Fri Feb 02, 2007 7:38 pm
coil shouldn't have anything to do with the fuel pump working.
Are you sure the coil is good. I assume you have no spark at the plugs either.
PostPosted: Fri Feb 02, 2007 10:03 pm
yea right i put a new coil on. and as you turn off the key it sortof sparks
PostPosted: Sun Feb 04, 2007 2:21 pm
i would check the wiring. Its possible the wires got hooked up backwards or one is shorted to ground...
Or maybe the resistor is making too much resistance (just gone bad)...
PostPosted: Sun Feb 04, 2007 7:07 pm
it runs!!!!!! wired it and now it runs one of the wires in the run psoition was grounding the coil. so the resistor got bypassed and now it just shut off!! and now there is no spark
PostPosted: Mon Feb 05, 2007 11:58 am
well cool deal!
 Post subject: .
PostPosted: Sat Mar 17, 2007 5:49 pm
What is the resitance in ohms, on a stock ballast resistor? My MSD set says it need a .08.
Thanks in advance
FIAA: Color Guard
PostPosted: Sun Mar 18, 2007 12:54 pm
I have somewhat of a similar problem. I can never remember what I did before - but it always seems like I am replacing the condenser on it.
Now I get no spark at the coil, and it's my daily driver.
 Post subject: .
PostPosted: Sun Mar 18, 2007 1:59 pm
I ended up changing points and new distributer..runs like a champ again. Actualy smoother than before, and I thought it ran good then :wink:
FIAA: Color Guard
PostPosted: Sun Mar 18, 2007 4:40 pm
i think i need a distributor
 Post subject: .
PostPosted: Sun Mar 18, 2007 4:45 pm
Their super-cheap at Autozone, 4 bux
FIAA: Color Guard
PostPosted: Sun Mar 18, 2007 4:46 pm
for the hole thing?
 Post subject: .
PostPosted: Sun Mar 18, 2007 4:51 pm
Yikes.... I meant the cap :lol:
FIAA: Color Guard
 Post subject: .
PostPosted: Sun Mar 18, 2007 7:07 pm
Can someone tell what is the actual, working point gap on a 79? I have tried the "range" given by the Haynes manual, runs good, but I still have a slight hesitation upon acceleration, and the tach goes kinda wiggy at around 4000 rpms, and occaisonaly does the "diesel" sputter at shutdown.
Only thing I didn't mess with much is dwell, I don't have a meter, so I jsut gapped it according to the manual.
FIAA: Color Guard
PostPosted: Sun Mar 18, 2007 7:39 pm
The haynes book should be correct. My series 8 manual says .016"-.020".
PostPosted: Sun Mar 18, 2007 7:45 pm
i dont have spark constantly now
i want msd!!!! :cry: no matter what i do i still have ok spark the engine will not run hardly at all but everything has been replaced but the spark plug wires. can that be the problem.?
PostPosted: Sun Mar 18, 2007 11:51 pm
yup
could be.
if they arnt very new then you should replace them.
like everyone else says.....
"the basics are your friends" :smt033
PostPosted: Mon Mar 19, 2007 12:17 am
Idealy points should be .018 (.016-.020). Dwell should be 52 (47-57).
Users browsing this forum: No registered users and 88 guests
