It is currently Sun Jun 28, 2026 10:13 am
 Post subject: 92 isuzu pickup
PostPosted: Sun Jan 21, 2007 11:04 pm
Well my friend has a 92 Isuzu that he is trying to get rid of
engine is no good
but is there anything that i could use from it??
maybe for power steering?
PostPosted: Sun Jan 21, 2007 11:06 pm
If it has a 5 speed it would work in a 2wd LUV. Also it would have a g200 motor.
PostPosted: Sun Jan 21, 2007 11:13 pm
would trans bolt up to the G200
and what about me having 4wd would the oil pan be diff?
PostPosted: Mon Jan 22, 2007 12:26 am
If the engine is carbed its a 2.3 and if it has fuel injection it is a 2.6.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jan 22, 2007 1:21 am
Swap Specialist Mod
yeah, i think the trucks after 87 had the 4Z series motor. like Dan said, if its carbed its a 2.3, and if its FI its a 2.6.
oh yeah, and if it has a 5 speed, send it my way will ya!! lol :D
PostPosted: Mon Jan 22, 2007 11:10 am
Yes, the oil pan would need to be swapped. DO NOT THROW AWAY THE 5 SPEED.
PostPosted: Mon Jan 22, 2007 11:09 pm
ooo move up to a 2L
Would i just swap my oil pan from the 1.8?
PostPosted: Mon Jan 22, 2007 11:19 pm
Swap Specialist Mod
if tis a 92 it wont have a g200. it will either have a 2.3 or maybe a 2.6. the oil pans from the Gxxx motors and the 4Zxx motors will not interchange.
PostPosted: Mon Jan 22, 2007 11:21 pm
So does it have a 5 speed?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jan 22, 2007 11:22 pm
My bad, I thought they were the same motor
PostPosted: Tue Jan 23, 2007 10:20 am
Banishment Pending
If it has the 2.3 or 2.6 and you want to stick it in the Luv I'm pretty sure you'll need to swap oil pans with a 4x4 Trooper/Amigo/Pup that had either the 2.3 or the 2.6 (I believe the oil pans are the same between the two engines)
Troopers from 86-87 had the 2.3 (all were 4x4)
Troopers from 87.5-91 had the 2.6 (again all were 4x4)
Amigos from 89-94 had the 2.6 (only the 4x4 versions though, the 2wd's got the 2.3)
4x4 Pups from 86-87(I think) had the 2.3
4x4 Pups from 88-95 had the 2.6
hope that helps
PostPosted: Tue Jan 23, 2007 5:22 pm
umm i duno if it has a 5 spd but i guess the engine is toast his says
But thats for the info
might have to look out for a 2.6L to replace my 1.8
Users browsing this forum: Bing [Bot] and 44 guests
