It is currently Fri Jun 12, 2026 10:39 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Lowered LUV
PostPosted: Sun Jul 07, 2002 8:45 pm
My Chevy LUV is 8 inches off the ground in the front and 9 in the rear. I like lowered trucks because you know when a truck is lowered by seeing it. I am going to lower it 2 inches in the front and 3 in the rear. I still need to get a pickup bed for my truck too. It is a longbed and it isn't easy to find a bed for a 1982 Chevy LUV or Isuzu PUP. Does anybody know anyone who may sell pickup beds for trucks and may have what I'm looking for?
PostPosted: Sun Jul 07, 2002 9:00 pm
If a rear end swap is nesecarry a s-10 rer is very easey to swap. As for amotor swap if you don't want to deal with av8 swap a 4.3 v6 is a good motor as it is very similar to a v8they are plentiful inexpesive and preformance parts are avail. and about 4 inches shorter so it shou fit fairly easey.
PostPosted: Sun Jul 07, 2002 9:02 pm
oooooopppppppsssss!!!!!!!! posted on wrug topic.
PostPosted: Wed Jul 24, 2002 1:00 pm
I have always thought of what to use to drop my truck with but I have made up my mind on what I want to use. I am going to buy Belltech Nitro Drop shocks. They sell two kinds of shocks, one with a single tube and one with a double tube. The price is $36.95 for single and $52.95 for double. I just hope when I buy the shocks it will be easy to lower my truck and not end up being a 2 day project. For you guys on the site that have lowered LUVs what did you use to drop your trucks?
PostPosted: Wed Jul 24, 2002 2:37 pm
When mine was "in the weeds" I just used 3" blocks for the back, and a big wrench to bring the tortion bars down in front till it sat on the rubber snubbers. Took me about two hours. :)
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Wed Jul 24, 2002 8:38 pm
Shocks do not lower vehicles, they are there to keep the ride smooth. To lower a LUV pretty much the only easy way is to adjust the torsion bars. It will ride a lot rougher lowered (mine rides like a tank!!) and the shocks wont help much so don't waste your money on the Bell Techs, if they even make them for a LUV. These trucks are nothing like the newer coil spring suspension trucks of today. You can put a newer clip under the truck or air bag it (My plans) but I don't think you want to go through all that work.
PostPosted: Wed Jul 24, 2002 9:10 pm
They don't sell the shocks for Chevy LUVs but they sell them for 1983-1995 Isuzu PUPs. Since I have a 1982 Chevy LUV, which is the same truck as an 81-87 Isuzu PUP, then I think I have a good chance of lowering it with them. These shocks are drop shocks just not any other shock here. They sell them to lower a truck, so I figure they will work. I just learned about how the Chevy LUV has torsion bars because my dad told me, so maybe I could just buy shocks for the rear drop.
PostPosted: Thu Jul 25, 2002 7:58 pm
Just want to point out one thing I don't think you understand about shocks. A drop shock wil not lower a truck, no shock will (air shocks will raise but not lower the suspension)! A drop shock is for already lowered vehicles that have less suspension travel. They have a shorter stroke. If you tried to put them on a stock height vehicle, they will not reach top and bottom mounts. As the other way, if you put stock shocks on a greatly lowered vehicle the shocks will be constantly bottomed out and blow out within a very short time. If you crank your torsions first and then get the lowered shocks, it will ride a little better than just the stock shocks As for the rear, you will have to get lowering blocks and modify the alignment holes on the axle as they are 2 small for the blocks.
PostPosted: Thu Jul 25, 2002 11:29 pm
I had the same problem with the drop-blocks, all i did to mine was grind on the peg sticking out a littlebit to make it fit better.
PostPosted: Fri Aug 16, 2002 8:49 pm
I bought 3" lowering blocks for the rear at Advance Auto Parts about 2 weeks ago and my dad and I are going to put it on this weekend. Since most of you guys said lower the front by messing with the torsion bars then that is what I might do. I might want to buy 2" lowering springs for the front. Does anyone know where they may sell lowering springs for Chevy LUVs or Isuzu PUPs?
PostPosted: Sat Aug 17, 2002 4:09 am
the torsion bars are your springs. U dont have coils unless somebody else has modified it.
PostPosted: Sat Aug 17, 2002 12:49 pm
CRAWL UNDER YOUR TRUCK YOU WILL SEE A LONG BAR THAT RUNS FROM YOUR YOUR FRONT LOWER CONTROL ARM TO YOUR TRANS CROSSMEMBER. ON THE BOTTOM OF THE CROSSMEMBER YOU WILL SEE A LONG BOLT ONE PER SIDE. YOU CAN TURN THAT BOLT TO RAISE OR LOWER THE TRUCK.KEEP TRACK OF HOW MANY TURNS YOU TAKE OUT & USE THE SAME AMOUNT FOR THE OTHER SIDE. SPRAY SOME PENETRATING OIL ON THEM FIRST IT COULD MAKE ADJUSTING A LITTLE EASIER. TERRY
PostPosted: Mon Aug 19, 2002 8:09 pm
Estimating, how long will it take to lower the front? I'm just wondering how long it would take since some of you guys went through it already on your trucks. I also wanted to know what is the maximum height you can drop the torsion bars? I'll be lowering mine just 2 inches and I already put the 3" inch lowering blocks on the back, it's crazy how low I have it in the back cause the front isn't lowered yet.
PostPosted: Mon Aug 19, 2002 8:24 pm
It's a piece of cake. I just adjusted mine a couple weeks ago. I took off the front bumper which actually raised the front of the truck 1/2 inch. So I crawled under it with a socket and a ratchet and gave each bolt about 2 turns.
 Post subject: Lowering the LUV
PostPosted: Sun Oct 06, 2002 2:28 am
Ben is right. I lowered my 79 Mikado ( Mick-aww-dough ) about 7 years ago with 2" blocks in the rear and adjusting the torsion bars to give the front a slight rake. I then went to the Kragen place and had the guy look up the specs for stock shocks ( they have the specs in the back of their books ). You can find the bolt-up in a shorter length. I run 225x60s in the back on 15x8 rims and 205x60s in the front on the same size rims. I had to roll the insides of the front fenders a bit, but they do clear.
PostPosted: Thu Oct 10, 2002 2:09 am
i lowered mine in about 2 hours.i used the torsion bars and 2 inch lowering blocks for the back.she rides pretty good.but i suggest to get some good shocks.i also suggest to lower each torsion one turn at a time.turn one side turn the other side or just count your turns.the first time i didn't count my turns and it took me forever to get my truck level again.
PostPosted: Mon Oct 14, 2002 5:26 pm
Well you can take a look at mine in the projects gallery and see how low mine sits! it sits about 5 inches from the body...... the frame is about 3 inces off the ground and that being the reason why I have ripped the muffler off 3 times!!!! :rofl: But what ever you doo make sure your exhaust is definitely tucked under nice and neat! lol
PostPosted: Mon Oct 14, 2002 7:18 pm
I haven't posted anything in awhile but i did lower my truck 2" in the front and 3" in the back. Its been lowered for awhile now, I'd say at least a month since I had it done. The only bad thing is when I lowered the back with 3" lowering blocks the drive shaft makes a sound because it is rubbing against something near the opening right at the end of the cab. I think my dad said it was a bearing or something and I would have to get a smaller one to stop the noise. Can anybody help me out with this problem?
 Post subject: U-joints
PostPosted: Mon Oct 14, 2002 7:30 pm
Did you replace your u-joints? Bryan
PostPosted: Mon Oct 14, 2002 8:32 pm
No, I didnt replace them but where are the u-joints located?
Users browsing this forum: Google [Bot] and 32 guests
