It is currently Mon Apr 06, 2026 3:57 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jan 02, 2007 11:20 pm
Did we answer your question or add more questions?
PostPosted: Tue Jan 02, 2007 11:29 pm
new is the way to go
PostPosted: Tue Jan 02, 2007 11:30 pm
pretty much answered and the answer is
it's gonna have to stay ugly for a little bit
but thanks for all the help
PostPosted: Thu Jan 04, 2007 1:20 pm
sleeps at LUVTruck.com
Did I mention that my dash is seperating? Here's some pics. :lol:
http://i47.photobucket.com/albums/f184/ ... 0_4069.jpg
http://i47.photobucket.com/albums/f184/ ... 0_4064.jpg
It's a little dirty. Haven't cleaned it in a while since it still has its use around the house. :wink:
PostPosted: Thu Jan 04, 2007 8:40 pm
That one is not half bad. I have seen much worse. A cap would cover that one up nicely.
PostPosted: Fri Jan 05, 2007 9:47 am
Are you sure, rondog because it is pulled up. I was afraid that I would have to cut chunks out of the dash.
PostPosted: Fri Jan 05, 2007 9:52 am
That truck has been in our family for almost all of its life and i'm proud of it. :D
PostPosted: Fri Jan 05, 2007 11:02 am
Okay LuvMyTruck, Rondog took the words right out of my mouth. That's exactly what I was thinking. A dash cap would take care of you. Where the edges are curled up go ahead and use a sharp utility knife and trim it off. Save the pieces in case you want to set some piece in the gap. You could fill the gap with anything, as long as it doesn't bulge or protrude. Make sure you try the cap a few times dry to check for fit. When you place it in with glue for the final time take three or four new and still-wrapped paper towel rolls and maybe a dozen toilet paper rolls and stuff them in with one hand while you and another person keep a steady forward pressure on the cap. Keep holding it by hand for a good ten minutes at least. I did mine during warmer weather and left it there overnight. It's solid and looks really great!! My dash was cracked worse than yours!! I didn't want to photograph it; it was embarrassing!! I do have some photos that show how bad it was though. Here's a before and after.
Image Image
Here's a dash: http://cgi.ebay.com/ebaymotors/72-73-74 ... otohosting
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Jan 05, 2007 11:36 am
okay guys thanks for the help i think i might get a dash cap
PostPosted: Fri Jan 05, 2007 11:51 am
ok on that link you gave me FullaLuv can you use the existing speaker grille or do you have to buy one on does it come with the cap?
PostPosted: Fri Jan 05, 2007 12:07 pm
The picture of the dash cap shows two openings for the defroster vents. You should still have those to use. The speaker for the radio was originally in the center of the dash; mine is now stereo and the speakers are on the doors. I don't have anything there where the center speaker used to be, do I covered it with some thing dark. The speaker grill is on the cap, so you shouldn't have to worry about the old one. Just be sure to fit the cap on dry as many times as you need to make sure it's going to lay flat on the dash and not be rocking over any high spots. It's a hard thick plastic and holds a form of it's own, but I wouldn't expect it to hover over empty space, so fill it all in. You might even glue the defroster vents down first and then add the cap. Take it slow and you should be fine.
Image Image
PostPosted: Fri Jan 05, 2007 12:14 pm
alright that pretty much answers my question thanks! :D
PostPosted: Fri Jan 05, 2007 12:31 pm
I would say that I agree with Ron and FullaLuv, you may think your dash is trash but it is in good condition and a perfect one for the cap. Buy the cap and put the extra money from not buying a new dash elsewhere in the LUV.
PostPosted: Sat Jan 06, 2007 6:37 pm
Hey FullaLuv, can I have an overhead view of your dash?
PostPosted: Sun Jan 07, 2007 11:24 am
In a while...
Image Image
PostPosted: Sun Jan 07, 2007 12:58 pm
Thanks, that would be nice.
PostPosted: Sun Jan 07, 2007 11:05 pm
I've been so busy all day...here's some photos of the dash. I'm going to explain that the LUV has been parked for some time, and a few cats have trekked across the hood and cowl and the wind has been howling. So the photos are a little uncomplementary to my taste, but they're here for you because you asked. I will also say that the dash looks better than this in actuality.
Image Image
Image Image
Image Image
PostPosted: Sun Jan 07, 2007 11:08 pm
:cry: i wish i had sumthing over my metal
PostPosted: Sun Jan 07, 2007 11:36 pm
you could do something like this for $15 and everyone that see it likes it
PostPosted: Sun Jan 07, 2007 11:43 pm
I like it, I think you did it very well.
Image Image
Users browsing this forum: No registered users and 61 guests
