It is currently Sat Mar 21, 2026 7:29 pm
 Post subject: Never seen one before
PostPosted: Sat Jan 06, 2007 5:19 pm
I have never seen an original LUV radio before, but I have one now. It's an original am only. This guy has an old cab that is mounted on an old military frame, and he told me that I could have whatever I wanted. I needed the drivers door glass and vent window, but when I saw the radio, I just had to get it too. :D I don't think that I will use it, but I wanted it anyway.
http://i88.photobucket.com/albums/k192/ ... radio2.jpg
http://i88.photobucket.com/albums/k192/ ... radio1.jpg
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat Jan 06, 2007 11:38 pm
Nice work. I know most people don't like AM radios but I like original things and frankly like a lot of the AM talk radio programs. Am I getting old?
Anyhow, if you ever want to get rid of it let me know.
Eric Q.
My build thread.
PostPosted: Sun Jan 07, 2007 12:03 am
My 78 had one in it when I bought it. My son swaped it out with somthing a little newer and louder. :roll: I still have the AM. If I remember right, it's in very good codition.
PostPosted: Sun Jan 07, 2007 12:10 am
I don't know if it works, but I plan on finding out. I need to check and see if I can find out how it wires up. I would hate to fry it.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sun Jan 07, 2007 2:55 pm
Rondog:
If you are interested in selling it shoot me a PM with a price. I assume it will fit the '75 dash w/o issue. Anyone know for sure?
luvmikado:
With that radio there shouldn't be more than about 4 wires. 1 for power, 1 for ground and the + & - for that hi-fi mono speaker. lol.
Intersting... Looking at the overview in the manual for '75 it shows a speaker lead that plugs into a seperate spot on the radio from the power lead. However, the wiring diagram shows the radio having a 4 wire plug containing power, both speaker wires and the antenna. I would assume then that the radio is chassis grounded.
The '75 manual shows the power connections as such:
Power - Blue
Antenna - Brown with black stripe (that should be easy to see :-) )
Speaker connection 1 - Brown with Yellow stripe
Speaker connection 2 - Brown with Red stripe
Good luck testing it out,
Eric Q.
My build thread.
PostPosted: Sun Jan 07, 2007 6:31 pm
This one only has three wires. Two that are speaker wires. I know that because they were still hooked up, but the other one was loose. It is blue. I figured it was a power wire. I guess that it is grounded when it is bolted in the dash. I just want to make sure before I try it out.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sun Jan 07, 2007 10:23 pm
I'm pretty sure that the blue wire is the power.
PostPosted: Mon Jan 08, 2007 3:42 am
Do the speaker wires match what I posted above? If so then I would bet money that the blue wire also matches. Go for it.
Eric Q.
My build thread.
 Post subject: stock radio
PostPosted: Thu Jan 11, 2007 8:51 pm
yep, I got one in my 80 still works. Sounds good too. I really don't to pull it out and replace it, but am getting tired of just am. So, I figure if I can mount a newer model radio somewhere else no one would really no the difference if I turn on the am radio and it lights up. Kind of sneaky but who cares. I'll still be original to a point albeit a small one that is
1980 Chevy Luv 4x4 Mikado
the "Ole Man from Spokane"
 Post subject: Re: stock radio
PostPosted: Fri Jan 12, 2007 7:13 pm
I plan on putting this one in my truck, but mounting my cd player in the glove box. That way it looks original, but will still rock.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Fri Jan 12, 2007 10:00 pm
I'm trying to design a console to go between the seats. Not much room really, and it's frustrating. My new radio am/fm is 7 in. x 7in. x 1-1/2 inch. You would think that would be easy to do, not so my friend, the glove box sounds better and better all the time.
