It is currently Wed Jun 17, 2026 3:01 am
 Post subject: 1.8 or 2.3
PostPosted: Fri Jan 05, 2007 4:22 pm
Im trying to decide which to build up. I have a completely stock 1.8 in my '80 longbed, and I have a line on a 2.3 with a blown head gasket/ cracked head. I'm looking for some opinons on which to hot rod. Any ideas? The 2.3 is out of an 86 pup
PostPosted: Fri Jan 05, 2007 4:58 pm
If you're looking for performance, go bigger.
PostPosted: Tue Jan 16, 2007 9:39 am
Take a look at these...
http://forums.luvtruck.com/viewtopic.php?t=12255
http://forums.luvtruck.com/viewtopic.php?t=12356
http://forums.luvtruck.com/viewtopic.php?t=10702
http://forums.luvtruck.com/viewtopic.php?t=10636
and maybe that will help.
If you have a choice...personally I would go with a switching to a 5 speed transmission and building up a bigger 4cyl engine. Partly to be original/different...and partly to get more bang for your buck without ending up too nose-heavy...or drastically altering the power-to-weight ratio or cornering ability/handling of your truck.
Just my $.02 worth.
Whatever you decide...please keep us all posted about your progress!
PostPosted: Thu Jan 18, 2007 4:56 pm
Yeah it looks like Im going with the 2.3 and the 5 speed out of an 86 pup. It will be n/a for now, but I am going to look into turbocharging it down the line. Not a lot, just enough to give me more than I have
PostPosted: Fri Jan 19, 2007 3:04 am
I think once you bore you engine out a little, add a cam, a header and a decent exhaust system, a weber with a custom intake, the higher geared rear end out of your donor truck, and the 5 speed too with a beefier clutch...you will be more than happy.
It is a huge step up...and IMHO...the way the damn truck should have been built in the first place....and if GM/Isuzu had back then..they would have been selling tons of them as fast as they could build them.
Now all you need is a step-side bed and you are all set to build and turn out one fine truck.
