It is currently Sat Apr 11, 2026 10:29 am
 Post subject: wont start
PostPosted: Tue Dec 05, 2006 8:00 pm
ok heres a ? my son and I or on the phone trying to get his truck started fuel is fine spark is good but still wont start any ideas? i whent threw the book but noting helped it sayed try fuel and spark but like i sayed no luck
PostPosted: Tue Dec 05, 2006 9:16 pm
timing,compresion,fireing order,
many little things could cause this .chill out then take another look.
Some times I can't see the forest for the trees
PostPosted: Tue Dec 05, 2006 9:19 pm
Is it cranking fine and just not firing ? Was it driving fine when he parked it ? That happend to my pop's truck and it turned out that he sucked the intake gasket and it was just problems.
-Austin
PostPosted: Tue Dec 05, 2006 9:20 pm
thats about what i told him ... give it a bit then go back and check again.. if i was there it would be easier for me to help
PostPosted: Tue Dec 05, 2006 9:22 pm
If it is a manual try push starting it poping the clutch and giving it the gas and keep it in a high idle. Then let it drop to and idle and if it dies it might be the voltage regulator.
PostPosted: Tue Dec 05, 2006 9:37 pm
ill tell him that one. didnt think of that well he tried again and still no luck fuel good spark ok motor tuns but wont fire up?
PostPosted: Tue Dec 05, 2006 10:17 pm
Check a fuse
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Dec 05, 2006 10:25 pm
yeah try rolling the fuses inside the fuse box to check connection
they are bad at just simply losing connection.
PostPosted: Tue Dec 05, 2006 10:58 pm
tried that getting plenty of spark
PostPosted: Tue Dec 05, 2006 11:10 pm
Just throwing out ideas here.
Did he just get gas? Could it be a bad batch of fuel??
You said good spark, but has he cleaned or replaced the plugs? He may be checking spark at the wire and not removing the plugs.?.?
PostPosted: Wed Dec 06, 2006 12:27 am
not sure will ask..
PostPosted: Wed Dec 06, 2006 9:01 pm
If it has been at all wet where he is, toss a can of gas dryer in the tank and flush the lines out. A little water goes a long way towards making it not start.
Just to be sure it has some good gas to burn you could try pouring a little bit of good gas down the carb throat. Not too much, about a tablespoonful or two at most. If everything else is good it should fire up for a few revs. If it backfires out the carb it means you have a timing issue, spark too early or valve closing too late. Not a bad idea to have a damp rag handy to smother the carb fire if it does decide to backfire.
PostPosted: Thu Dec 07, 2006 12:01 am
ok thanks.. he heads to the field tomorrow so we will have to wait a week now to find out
Users browsing this forum: Bing [Bot] and 43 guests
