It is currently Mon May 25, 2026 11:17 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: Rear ends
PostPosted: Wed Dec 06, 2006 3:33 pm
I have a turbo 350 trans in my 77' chevy luv. What would be a good rear end to put it for not alot of money? It currently has the stock rear end
PostPosted: Wed Dec 06, 2006 3:57 pm
Most get a rear end out of a S-10. They are easy to come by and gears are available and a direct bolt in. If you have decent H.P. this may not be the way to go. I run a 9 inch and some believe in Dana's. The S-10 rear will hold up fine on the street with a mild small block. If you do run slicks or if the truck hooks up real well you may want to look into something else. Roadshow Bob has the S-10 rear end out of my stock V-8 Luv conversion and would be happy to sell it, it worked great for me and is quiet. I replaced it for a 9 inch when I back halved my LUV.
PostPosted: Wed Dec 06, 2006 4:33 pm
I run a ford 9 inch in mine just because mine is purely for racing. Luvrv8 is right in what he said about the s10 rear. But if you have a mild motor now and plan to go bigger later, i would go ahead and find a nice for rear to save the hassle and cost later down the road
79 luv drag truck
2 skidoos
2 quads
badass duramax diesel
PostPosted: Wed Dec 06, 2006 5:51 pm
With the Racing associated with your forum name, I would suggest going straight to a Ford 9" assy with a high spline count.
An S-10 will get you on the road better that a stock axle, but if you plan to throw some power out, sticky tires on a sticky track will kill an S-10 axle.
PostPosted: Wed Dec 06, 2006 6:00 pm
Blue Meanie Said It Pretty Good.
S-10 Rear End If You Going To Run A Stock-Mild V8. As Long Your Not Hooking Up Hard.
Anything Bigger/Stronger You Will Need To Go With Either A Chevy 12 Bolt, Ford 9", or A Dana
I Have A Ford 9" Under My Mikado.
PostPosted: Wed Dec 06, 2006 7:20 pm
I have heard the Dana 44 out of the old mail jeep fits well . I run a narrowed 9" from a 79 bronco with replined axles and redrilled truck drums .
PostPosted: Wed Dec 06, 2006 7:40 pm
My Rear Axel Is A 9" off From Under A Mid 70's Ford Granada. Works Well For Me.
PostPosted: Thu Dec 07, 2006 8:39 am
9 incher.
PostPosted: Thu Dec 07, 2006 10:22 am
We sure are quick to bragg about or 9 inch's.
PostPosted: Thu Dec 07, 2006 11:39 am
It's because 9" assy's are the bomb! It's strong, easiest to narrow out of all production assy's, easiest to do a gear change of all production assy's (if you have a spare 3rd member). No stupid c-clips. Everone builds replacement parts and kits for them. Once you get one under the vehicle, you'll never think of it again.
I think i'll send Currie and Strange a Christmas card this year.
PostPosted: Thu Dec 07, 2006 1:06 pm
Couldn't have been said better.........and there is about million spares laying around if you do break one :D
PostPosted: Thu Dec 07, 2006 2:59 pm
so sounds like 9' will be a good choice and a cheap one. i'll be running street and strip so it sounds like that will work good. I have the stock end at 4:10 gear ratio so it likes to move quick! 8)
PostPosted: Thu Dec 07, 2006 3:04 pm
Yeah, My 9"Currently Has A Set of 513's, I Am Currently Looking For Etiher A Set of 456's or 410's..lol Just A Little To Much Gear.
PostPosted: Thu Dec 07, 2006 3:09 pm
Yeah thats why i might put in another rear end. plus i'm looking to upgrade to a 350 so need a better rear end
PostPosted: Thu Dec 07, 2006 3:14 pm
Yeah Well Good Luck With Your 350 Swap, And Happy Hunting on A Rear End. Shouldn't Be That Hard To Find.
PostPosted: Thu Dec 07, 2006 3:32 pm
Now the phrase "cheap" is in relation to other axle assy's. Building a replacement rear end can cost more that a motor build. Sometimes someone can find a differential for a few hundred bucks or less, get it all cut down to size for a few hundred (if they know the right people) and then you'll need a driveshaft (up to 350 for a good one with a warranty). If you have connections in the hot rod crowd, you can pull it all off for as little as 500 bucks. Going retail for a complete running setup can put you over 2000 dollars easy. Getting a custom axle assy isn't cheap but working a Ford 9" to fit is the best bang for the buck.
PostPosted: Thu Dec 07, 2006 3:47 pm
I Scored My Rear End For $50. But I Normally Send My Rear Ends To A Guy Here In Town He Norm Will Cut Everything Down Housing, Axels, And Make Sure Everything Is True For $100-400 Depending on How Busy He Is. I Have Bought Whole Rear Ends For Dirt Cheap Before. He Is Also The One Who Builds My Drive Shafts He Normally Will Knock One Out From Scratch For $50-100 Again Depending On How Much Time He Has. He Does Really Great Work. And Anyone Around The North Georgia Location I Would Suggest To Go To Him. He Probably Wont Give The Same Prices Due To He Has Been Friends of Our Family His Whole Life, and In Pedicular Really Close Friends With My Older Brother. So I Sometimes Can Get A Home Boy Hook Up.
PostPosted: Thu Dec 07, 2006 4:08 pm
That's what i mean by being connected.
I was having a hell of a time when i recently reworked my Ford 9". But after asking the some of the parts counter guys on who has a solid reputation with Ford 9's, they referred me to a fella that hooked me up good. He showed me how really screwed up my axle housing was and offered me a stronger replacement housing. Either shell out some money to fix the problems of the old one, or spend the same amount and get a better housing. The labor was cheaper to build a replacement that to work over the old one.
So now my setup is running at 100% of its capability. And i got a good connection to a machinist gearhead.
PostPosted: Fri Dec 08, 2006 12:52 am
I paid 500 to narrow mine . After I was finished a friend told me he does them and would have done it for free . :roll:
PostPosted: Fri Dec 08, 2006 3:35 am
Nothing like having guru buddies my rear end setup was free too unless you count the cost of beer for two weeks for one worker and three supervisors :lol:
