It is currently Mon Jun 08, 2026 2:27 pm
 Post subject: Fuel filler hose size?
PostPosted: Sun Dec 03, 2006 6:34 pm
Anyone know what the ID of the fuel filler hose is for a 1978 Luv? I don't want to take it off until I have the replacement hose in hand so it is hard to guess for sure.
PostPosted: Sun Dec 03, 2006 8:20 pm
Should be 5/16".
PostPosted: Sun Dec 03, 2006 8:21 pm
Sorry wrong thing
PostPosted: Mon Dec 04, 2006 5:28 pm
I dont remember the I.D. but the NAPA part # is NBH 1035. It took me forever to find a suitable replacement for mine when i removed my tank.
PostPosted: Mon Dec 04, 2006 5:32 pm
Fullaluv May Be Able To Tell You If Its Stamped On The Factory Hose. He Would Be Able To Look At The One I Sent Him.
PostPosted: Mon Dec 04, 2006 9:28 pm
Right. I'll look...
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Mon Dec 04, 2006 9:53 pm
Here's a couple photos of the hose. BlackLuv80: You should get your payment very soon!!! LOL
There aren't any numbers on the hose. Maybe if I wash it with soap and water I might be able to see some numbers, but I measured it, and it's a 2" inside-diameter hose, so perhaps that info will help. It's pre-curved and about 13½" in length. I bent the measuring tape to the curves to get the length.
Image Image
PostPosted: Mon Dec 04, 2006 9:59 pm
You Should Have Seen It Before I Cleaning It. :lol: Ever Heard of Red Georgia Clay? Need I Say More?
PostPosted: Mon Dec 04, 2006 10:15 pm
Why you done washed off the numbers!!! I needed that dirt to make my tomatos grow bigger! LOL
And oh, I haven't worked on the LUV for three days. Gettin' lazy. I cancelled my appointment for inspection. New date is Jan 8.
Image Image
PostPosted: Mon Dec 04, 2006 10:21 pm
I Thought It Was Illegal To Transplant Dirt From One Side of The Country To The Other.
Well I Guess That Means No Luck on A Actual Factory Part Number. Sorry, Maybe Someone Else Can Round It Up.
PostPosted: Mon Dec 04, 2006 10:26 pm
Hey I got a manual off eBay tonight! It's a Series 8, for my '78. Maybe when it comes I can find that in there. I dunno, but LUVTruck.com has some reference stuff you can look up...
I'm goin' to look...
Image Image
PostPosted: Mon Dec 04, 2006 10:43 pm
I don't know where to get that info. Maybe someone has a parts CD or whatever it is you need to find that. I cleaned my first one and wrapped it in Gorilla® tape and it worked fine. I only used it once though. I wanted a whole one.
78inIowa, is yours cracked? In the middle? Take it off, and wash it in the kitchen sink with dishsoap and hot water. Dry it well, maybe blow dry it some more with a hair dryer. Tape it very tightly over and over and it should run awhile.
Image Image
 Post subject: Thanks!
PostPosted: Tue Dec 05, 2006 10:37 am
Thanks for the help guys. I think we will try the wrapping technique first, it may get us through until we find one or order one.
 Post subject: hose part numbers
PostPosted: Tue Dec 05, 2006 1:53 pm
Don't know if this helps you, but the OEM part number for that hose should be 94026175 according to the parts manual. They used the same hose for series 6,8,9,10. Should fit 1977 - 1980 trucks.
1980 2wd Stock
