It is currently Tue May 26, 2026 12:46 am
 Post subject: Wet Feet
PostPosted: Thu Nov 23, 2006 12:55 pm
I am a new Chevy Luv owner. Eventually I'll convert it to run on waste vegetable oil like my car. I'm trying to fix it up a bit first. Water keeps filling up the floor of the cab when it rains. I have looked everywhere and can't find the leak. Are their some common leaky spots that I might not have seen?
 Post subject: More info...
PostPosted: Thu Nov 23, 2006 12:57 pm
Oh yeah...the leak seems to be worse on the passenger side but there is also water on the floor of the drivers side. Any ideas?
PostPosted: Fri Nov 24, 2006 12:57 am
Get someone with some food coloring died water(red?) in a bottle. Poor it slowely over the front window trim. Over the cowel. top of the windsheld. Cab drains on the roof. Someone needs to be inside to find it with a good light too see it. Start in the lower areas and work up. I guess you could put some kind of smell in it too. I coud help..
Like a leakly hearter core with antifreeze, The smell and wet will tell you whats wrong with.
PostPosted: Fri Nov 24, 2006 3:54 am
I just resurrected the thread, but I did a writeup of fixing leaky wiper shafts quite a while back that may help. Seems to be a common source of leaks.
http://forums.luvtruck.com/viewtopic.php?t=849
My 79 still fills up with water though, I need to get agressive with the sealant around the windshield gasket. I've found some stuff recently that it is designed for windshield gasket leaks, basically silicone sealant that is cut real thin to run into all the little places water uses to get in the truck. It worked great for fixing leaks on my 77, just have not gotten around to using it on the 79.
PostPosted: Fri Nov 24, 2006 10:09 am
If the passenger side floorboard gets soaked more than the drivers side, inspect the antenna. Water gets underneath and flows down the cable into the cab. I had this problem and found it when i noticed the kick panel was wet.
Use some rtv on the antenna base and feed some cable back thru the kick panel.
PostPosted: Mon Nov 27, 2006 3:55 am
I had a similar antenna cable issue. Every winter the passenger side would getwet. There was so much dirt packed between the inner and outer fenders that the water just ran right in the hole for the antenna cable.
I cleaned out the dirt and filled the hole with silicone. No more problems.
You went there in that?!?!
 Post subject: Cable?
PostPosted: Tue Nov 28, 2006 10:58 pm
you wrote:
what's rtv? and what do you mean feed some cable back through the kick panel? What cable and what's the kick panel. Sorry for the inexperience here I am new to this and to Luvs. I am getting a crash course though.
PostPosted: Wed Nov 29, 2006 1:54 am
I think the cowl is the problem with alot of these trucks water goes in with dirt plugs the drains and it eventaully rides down the cab on the kick panel areas check to see if you have rust at the kick panel area
PostPosted: Wed Nov 29, 2006 2:55 am
The kick panels are the area where your feet go, and since most of the non drained water or the antenna leakage leads right there, so lift your carpet up and check that area for rust. But ya, thats what the kick panels are :)
-Austin
PostPosted: Thu Nov 30, 2006 2:12 am
rtv is a silicon sealer. Any sort will do even the plumbers stuff. Just make sure the surfaces are clean and have no oil on them.
Kick panel is the trim beside your outside foot. Its usually made from compressed board in older cars. Masonite (dark brown tile underlay stuff) or similar.
The cable is the one for the antenna or aerial for the radio/wireless. Trace it from the antenna or from the radio.
I think the feed some back bit is to make sure youve got some slack. Wires should never be pulled tight as this will encourage them to rub thru. Also if youve got a bit of slack you can move the wire around to get it out of the way or route it differently. If you stick it in with silicon it will be fixed and you cant slide it in and out of the passenger compartment.
It should have a propper sized rubber grommet around it.
If you look under the front mudguard at the back of the wheel you will see where the mud/dirt builds up. Its a good idea with any car to give this a good clean out as often as you can. Dirt holds moisture and moisture premotes rust.
Cheers, Bob.
PostPosted: Sat Dec 02, 2006 12:38 am
room temperature vulcanizing RTV
PostPosted: Fri Dec 08, 2006 12:10 am
I had trouble once and found out the drains for the grate behind the hood (cant think of name of it) right under winshield where wiper shaft comes out. was cloged so i went under neath and pushed a wire up through it and junk com out and no more leak. :wink:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
 Post subject: water in floor
PostPosted: Fri Dec 08, 2006 4:10 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
it sounds like you may have some rust behind the windshield gasket mine had a small hole at the base of the windshield channel when i was painting it i had the glass out and fixed the hole it was very small but that was all it took to leak inside the truck.
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
