It is currently Sun Dec 14, 2025 9:17 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Stock S10 Rear End
PostPosted: Tue Sep 05, 2006 4:09 pm
Is the width of these the same as a stock Luv rear end? Direct bolt up?
2nd question- I have a turbo 350 transmission and a a 10 bolt 28 spline s10 rear end I just aquired. What is everyone using for drive shafts? Stock?
PostPosted: Tue Sep 05, 2006 4:44 pm
Yes the S-10 rear is a bolt in but I think a new driveshaft will have to be made.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Sep 05, 2006 5:51 pm
Thanks Dan. That's what i wanted to hear.
Is everyone starting with a certain specific driveline to get the work done? Camero?
PostPosted: Tue Sep 05, 2006 10:01 pm
i believe a stock automatic 2nd generation camaro driveshaft will be a bolt in
PostPosted: Wed Nov 01, 2006 1:48 pm
so if i get a stock s-10 rear end it will bolt right in?
i have the stock motor in still, so will the drive shaft bolt right in to or do i need to get one made.
PostPosted: Wed Nov 01, 2006 2:08 pm
you will have to get one made
Im luvin it
PostPosted: Wed Nov 01, 2006 2:42 pm
Isn't The S10 Rear End A Hair, Maybe A Sliced Hair Wider. Still A Direct Bold In and It Looks and Works Great.
Yeah A 70-81 Camaro, Fire Bird, or Trans Am Drive Shaft Will Work, Make Sure Its A TH 350 Car For The Correct Length, TH 400 Are Slightly Longer, There For Slightly Shorter Drive Shaft. Also Most TA's & Fire Birds W/ Pontiac Engines Will Have Shorter Drive Shafts.
Also A Mid 70's Granada W/ 8.8 or 9" Works Well. You Will Have To Weld Leaf Spring Perches Seeing That They Are None. You Can Norm Buy A Set Of Perches For 20-30 Bucks.
Happy Hunting
PostPosted: Wed Nov 01, 2006 2:57 pm
hes right about that if you are doing a v8 swap
BlackLuv80 Yeah A 70-81 Camaro, Fire Bird, or Trans Am Drive Shaft Will Work, Make Sure Its A TH 350 Car For The Correct Length,
Im luvin it
PostPosted: Wed Nov 01, 2006 3:00 pm
Didn't I Say That...lol
PostPosted: Wed Nov 01, 2006 3:03 pm
he has a stock motor
Im luvin it
PostPosted: Wed Nov 01, 2006 3:14 pm
So.....It Will Hold Up...LOL!
PostPosted: Wed Nov 01, 2006 3:23 pm
so i have to get a new drive shaft with the stock luv engine and trans?
PostPosted: Wed Nov 01, 2006 3:24 pm
yes
Im luvin it
PostPosted: Wed Nov 01, 2006 3:25 pm
is there any drive shaft i can pick up that will fit, instead of getting one made
PostPosted: Wed Nov 01, 2006 3:31 pm
Happy Hunting
Yeah maybe
PostPosted: Wed Nov 01, 2006 3:34 pm
s10 blazer might fit
Im luvin it
PostPosted: Wed Nov 01, 2006 3:37 pm
Prob Would.....considering you had a TA Drive Shaft in your jimmy
PostPosted: Sun Nov 05, 2006 9:06 am
Just in case I missed it.....could someone tell me what year model S-10 rear ends will work ?? My LUV is 4wd.....how will that complicate finding the correct differential ?? I've never swapped out a rear-end before, but the one in my LUV is toast.
1980 LUV Mikado 4x4, 155K, stock
PostPosted: Sun Nov 05, 2006 9:44 am
I think almost everyone here will suggest the first years S-10 axle for the rear.
The 2WD rear axle.
The one in the truck I have has an Eaton style posi as an option.
If you were looking to get a Posi, I believe the later year S-10 Posi untis were GOV-LOCS and these units were not as strong as the Eaton types. Just something extra to consider!
Someone here will share the dimensions for the 2WD and the 4WD widths differences that I do not know...
Can someone here with knowledge about these axles elaborate if there were any metric or standard thread changes ever on these over the years that these were made?
Thanx!
8)
PostPosted: Thu Nov 16, 2006 7:04 am
Bite your tongue.
350 ci bored .20 over
Speed Pro Hyper. Pistons
Blueprinted cast crank
full rv cam
67 camel hump 72 cc heads
holley street dominator manifld
edelbrock 750 cfm carb
msd 6a
That had better perform bettter than stock or I'll pitch the entire project.
