It is currently Tue May 26, 2026 12:52 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Oct 30, 2006 6:20 am
:shocked!:
LOL!!!!!!!
You've Gotta Point I Guess
PostPosted: Mon Oct 30, 2006 9:06 pm
Looks like a pretty solid truck, and the price was certainly right. The cylinder walls look ok, and the dings in the pistons don't look too bad from the pics. I bet it will fire up if you get a good head on it, and get the timing right. Just assume that everything that is clean, new, or looks like it was worked on is completely screwed up. It looks like it had a prior owner with some mechanical issues. Could be the timing chain broke and they just replaced it without pulling the head, but its probably more likely the prior owner just worked on it until they broke it too badly to be brought back.
PostPosted: Sat Nov 04, 2006 3:45 am
Swap Specialist Mod
well i got it runnin kinda with the help of lee and some other friends.
the stock carb that came on the truck is a POS. leaks like a sumbitch, so im gonna try lees stock carb from his truck and see if ittl work better. it should, since its was a new re manufactured one.
there is one thing thats bothering me though. when its runnin it has a a pop from the exhaust. what does this mean? im thinkin that the rockers might be a little tight.
anyways, here a pic of what it looks like as of now...
PostPosted: Sat Nov 04, 2006 4:47 am
Most Likely Either Flooding, Vacuum Leaks, The Timming Is A Little Retarded, or Maybe Plugs?
I'd Check The Carb 1st You Said It Leaked Like Crazy
Glad To Hear It Runs Not Bad, A Free Truck That Runs.....Who Can Complain?
PostPosted: Sat Nov 04, 2006 1:37 pm
cool get a good carb on it .
PostPosted: Sat Nov 04, 2006 3:44 pm
With the leaks you describe in the carb, I'd bet that is where your pop is coming from. You could have excess gas running in the carb, a vac leak around or in the carb, all sorts of crap could be going wrong.
PostPosted: Sat Nov 04, 2006 7:43 pm
LUVTruck.com's Cornholio
Rick wrote:
Alright Neil, it's nice to hear of your good fortune. What a good friend you have in Lee, who was on the look out for you. 8) :lol: :lol:
Damn right! 8)
no but really its so cool to have a bunch of luvs around. Saved another from the crusher. Thats always good.
PostPosted: Sat Nov 04, 2006 7:47 pm
well tonight we hooked everytihng back up and cleaned out the gas tank. put a fuel pump on it and BAM fired right up. Drove it around the block a couple times. that thing runs as good as my truck. doesnt knock tick or nothing! I am jealous....
PostPosted: Sat Nov 04, 2006 9:14 pm
well congrats on the running new toy :lol:
PostPosted: Sun Nov 05, 2006 3:54 am
Swap Specialist Mod
yep thats right!! we drove it around the block a couple times, and then a couple times more a few hours ago.
it still has a small pop, but it only when i give it some throttle real fast. this thing runs sooo smooth. even with the stock piece of shit hitachi on it.
there is alot more work to do to this thing though. ive got a feeling that im gonna be dropping the tank to clean it out. theres a fair amount of shit in the tank, i think. i bought a bunch of fuel filters, so i hope that runnin a few tanks of gas though it will clear that up.
then the brakes feel like they need bled, the clutch need adjusted, and there might be a small wiring problem with the running lights and turns signals. im betting its just a bad ground.
so, im gonna get as many of the mights on the thing workin as i can, and then im gonna go get this thing registered!
PostPosted: Sun Nov 05, 2006 4:14 am
Well I Commend You On Your Great Work. Knew Ya You'd Get It Running.
So It Pops When You Give It Gas?
Or When You Give It Gas And Let Off?
I Noticed You Have A New Cap n Wires on It Maybe The Timming Is Slightly Off? Need To Advance It A Little? Not Really Sure.... Well It Great To Hear You Enjoy Your New Truck And Finnally Got To Take It For A Test Drive.
PostPosted: Sun Nov 05, 2006 8:43 am
Wow, I must of missed this post :? Great score!!!!!! A little elbow grease and some luv, shell be good to go 8O
PostPosted: Sun Nov 05, 2006 1:38 pm
Congrats on getting it running! 8) You got a killer deal on that truck man.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Nov 05, 2006 3:47 pm
Farmer Joe, you are one lucky Dude.
PostPosted: Mon Nov 06, 2006 1:34 am
Swap Specialist Mod
mkay, i got all the lights workin now. im gonna get a new headlight tommorow, and then itll be good to go. im gonna have to get this thing registered and insure this week. the pup is startin to take a crap on me now.
heres some pics of it as of tonite...
i still need to do some small stuff to it like adjusting the clutch and bleeding the brakes. im gonna be parking the pup for the winter. i noticed that it has a small knock, so i dont wanna run it alot more so i can keep the bottom end together. ill prolly rob the weber off it to put of the luv. the hitachi isnt cuttin it.
PostPosted: Mon Nov 06, 2006 2:02 am
And another one ends back home....on the road
bummer about the mini-knock though
PostPosted: Mon Nov 06, 2006 9:47 pm
dude.. we have matchin 77's... kinda
its bout time tho
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Tue Nov 07, 2006 1:50 am
Swap Specialist Mod
its bout time tho
heck yes! lol.
had a damn heater coolant hose blow out today when i was drivin it. the one that goes from the underside of the intake to the front of the head. so i gotta get that out of there for a new one. im not lookin forward to doin that.
PostPosted: Tue Nov 07, 2006 1:03 pm
Banishment Pending
awww come on that a piece of cake to get out....don't ask how I know :roll:
PostPosted: Tue Nov 07, 2006 6:25 pm
its bout time tho
another 77 here too. :lol:
