It is currently Tue Jun 09, 2026 12:15 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Brake problem Need Help.
PostPosted: Wed Nov 01, 2006 8:11 pm
Ok the new truck is home needing shocks as they are 31yrs old. Ok the brake question. The brakes on my 76 are to the floor I see no rust anywhere on the undewrside and the brake lines are clean. The front resivoir on the master cylinder was full the rear was empty Pedal goes to the floor whats wrong so I can take it out before snow flies. Anybody Please
PostPosted: Wed Nov 01, 2006 8:47 pm
Maybe leaking between the master cylinder and the brake booster, which is hard to see. Mine was leaking there,but showed no sign of fluid.
PostPosted: Wed Nov 01, 2006 9:23 pm
could be the rear wheel cylinders leaking.
PostPosted: Wed Nov 01, 2006 9:32 pm
no the front resivior is full thats the back according to my repair manual the back is the front
PostPosted: Wed Nov 01, 2006 9:48 pm
Mine was doing the same thing yours is. The back reservoir would go low when driving. Check all the wheel cylinders no fluid, check the calipers no fluid, looked at the master cylinder no fluid. But when I took off the master cylinder I could see fluid in the bore. What was happening was the master cylinder was leaking when I applied the brakes, It would pressure out the bore between the cylinder and the booster.
PostPosted: Wed Nov 01, 2006 9:58 pm
and where was the fluid as I dont see any leaks and what do I do?
PostPosted: Wed Nov 01, 2006 10:08 pm
Most likely the fluid is leaking from the master into the booster. You will not see a leak if the fluid is doing this. Pull the master from the booster and have a look, its only a 5 min job.
PostPosted: Wed Nov 01, 2006 10:22 pm
if thats it what do I do then?
PostPosted: Wed Nov 01, 2006 10:24 pm
Clean out the booster the best you can, replace the master and drive away happy.
PostPosted: Wed Nov 01, 2006 10:34 pm
thanks try in the am
PostPosted: Wed Nov 08, 2006 9:36 pm
I guess I'll just take it somewhere and have it fixed I mind as well have them do the shocks as well. I dont know which way to go
PostPosted: Wed Nov 08, 2006 9:48 pm
That is your call, but the work is easy. I would rather see you do the repairs and put the extra money you saved into another part of the LUV. In my opinion if you pay to have your LUV fixed every time something needs to be fixed, it will add up quickly, these are older cars and will take a little more repairs to keep them going.
PostPosted: Wed Nov 08, 2006 10:05 pm
yeah but I dont have the time and wanted to drive it a least once
PostPosted: Wed Nov 08, 2006 10:41 pm
It is your call, but with a master in hand and a friend to help bleed the brakes I would assume it would take the same amount of time to take it to a shop and then pick it up.
PostPosted: Thu Nov 09, 2006 12:06 am
I got to go with Luvrv8 on this. Do these tasks yourself. The cost outlay will bum you out along with the fact that some half-assed mechanic slaps stuff together that you may need to rework to get it right.
Some stuff needs to go to the shop because you dont have the equipment like wheel alignment, welding, machine shop services and the like because it isn't practical to have such items unless you can make money with them.
But to remove and replace components with basic hand tools keeps you from spending more money that you need to. Plus it's satisfying to make something better than it was.
PostPosted: Thu Nov 09, 2006 12:46 am
ok i'll do it this weekend
PostPosted: Thu Nov 09, 2006 12:52 am
That is the spirit.
PostPosted: Sat Nov 18, 2006 6:35 pm
Ok the master cylinder is wet looks like it leaks between the booster and the master. should I replace the master as if it is leaking and even if I clean the booster outwont it just do it again?
PostPosted: Sat Nov 18, 2006 6:46 pm
Yep... Carefully remove the plastic resevuiors and swap it out with a new one. You could try and rebuild it but it's just best to turn the old one in as a core.
PostPosted: Sat Nov 18, 2006 6:53 pm
thanks
