It is currently Sun Jun 28, 2026 2:05 pm
 Post subject: 4.3 info please
PostPosted: Wed Sep 27, 2006 11:48 pm
is a 1988 4.3l Chevy V6 . is the flywheel the same as the 1 on a 350?
:microwave: :lol: this ? dives me nuts
PostPosted: Thu Nov 02, 2006 1:13 am
it is the same as a 1988 350
Im luvin it
PostPosted: Thu Nov 02, 2006 2:40 am
Unless its The Small Fly Wheel..but most likely is the same
PostPosted: Fri Nov 03, 2006 7:48 am
Allot of 4.3's used the 153 tooth flywheels some the 168 and the can be used off a 350 just remember to use the right starter.Stager mount 168 straight mount 153.
PostPosted: Fri Nov 03, 2006 12:04 pm
i have a 1988 z code moter
PostPosted: Fri Nov 03, 2006 12:08 pm
how is it balanced ? interol or ex ?
PostPosted: Fri Nov 03, 2006 9:28 pm
The only externally balanced SBC was the 400.
PostPosted: Sat Nov 04, 2006 10:02 am
Not so some of the late 80's 305's and i think some 350's with the full circle cranks had external balanced flexplates :?
PostPosted: Sat Nov 04, 2006 7:10 pm
I would have thought that the V6 flywheel would have been externally ballanced too considering how complicated the crank shafts are to get the firing order. But then i dont know much about them.
Bob.
PostPosted: Sat Nov 04, 2006 9:31 pm
283, 302, 305, 327, 350, 4.3 V6 & V8 Are All Internally Balanced
400 Is The Only SBC Thats Externally Balanced From The Factory.
(Almost Completely Positive)
PostPosted: Sun Nov 05, 2006 4:50 pm
The full circle crank engines had balance pads on the flexplates because there was no balance pad on the back of the crank.
