It is currently Sat Mar 21, 2026 4:42 pm
 Post subject: Speedometer cable
PostPosted: Tue Sep 12, 2006 12:31 pm
How can I convert the factory speedo cable to work with my turbo 350? Can I just change the inside part ? It has the wrong end at the transmission on the drive cable. I need a square end.
PostPosted: Tue Sep 12, 2006 2:43 pm
I just bought a new one since they're not that expensive.
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Tue Sep 12, 2006 3:50 pm
i uesd the 1 from a camro and modifed the end to the speedo
PostPosted: Tue Sep 12, 2006 4:10 pm
I used the stock LUV cable and used a grinder to change the end to the trans as needed.
PostPosted: Tue Sep 12, 2006 6:37 pm
I used a repair kit from napa autoparts. I just ground off the old end and clamped on the new rapair end. don't shorten the cable at all. The napa p/n is 615-1823 it was only $2.09 plus tax!!!
PostPosted: Wed Sep 13, 2006 10:19 pm
What a score. I had the same question.
thanks
PostPosted: Thu Sep 14, 2006 12:00 am
Yea, sounds like you , me , and Dan M are at the same piont.
PostPosted: Fri Sep 15, 2006 8:08 pm
Yea, I was there a short time ago. I decided to order a Lokar speedo cable for the turbo 350 then got an after-market speedometer (Auto Meter) and custom fit it to the cluster.
PostPosted: Fri Sep 15, 2006 8:11 pm
I forgot to mention, after all this work, I do plan on going faster than 80mph :)
