It is currently Fri Dec 12, 2025 6:43 pm
 Post subject: resplined axle
PostPosted: Tue May 23, 2006 8:15 pm
Well I got the rear axle back today. The axles were sent to moser to be cut and resplined anybody have any experience with resplined axles? Good or bad.
PostPosted: Tue May 23, 2006 9:56 pm
Japanese Redneck
its the same axle u had before, just shorter. strength is the same. I ran some stock 9" axles cut and resplined (28 spline) for years with 10.5" slicks 3.70 or 4.30 gears, posi, mini-spools, 4500 stall nitrous launches... never broke one. never even broke the stock 1/2-20 wheel studs in them either. I only changed it out because the local track made me. I still run the axles in another street rear end. These days anymore for the amount of $ u spend having them narrowed and resplined you can get a nice set of custom alloy axles for just a little bit more and have piece of mind.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Jul 21, 2006 8:43 pm
what is the torque spec. for a 1980 4x4 luv, rear axle bearing lock-nut?
PostPosted: Sat Jul 22, 2006 3:19 am
Series 9 (1979) is 190 lb-ft...
I wasn't able to get it free with any tool I had at home and ended up paying a shop to do the work on mine...
-DK
PostPosted: Sat Jul 22, 2006 7:35 am
My 31 spline axles were cut and resplined.mini spool, and Moroso wheel studs and no problems :) :)
PostPosted: Sun Aug 27, 2006 2:41 pm
Moser would have advised you of any potential problems with your original axles. If they questioned anything, they would have tried to talk you out of using them in favor of one of their sets.
 Post subject: axles
PostPosted: Sun Aug 27, 2006 4:02 pm
had mine done by moser ,so have all the guys I run with never had any problems.
PostPosted: Sun Aug 27, 2006 7:24 pm
Well the axles came with a sticker on them that said not responcible for damage . The axle place tried to talk me into summers bros. I personally don't think it will hook up . to much power and not enough tire. I will do my best to drive around this . Hpoe the track is preped. I'm ready to make a pass . I made 98 last year and have not made 1 this year. Even got kicked off for not having long pants in the powerstroke .
PostPosted: Sun Aug 27, 2006 7:44 pm
They were reworked to your specs so if it breaks, it's on you. They didn't have the housing to verify axle lengths. Just make sure that the axle ends dont press against the carrier pin. The splines will line up well before the bearing meets the housing. I had to get one of my axles turned down because it was binding on the carrier pin.
If the bearing bottoms out in to the axle housing and the axle doesn't bind up when you rotate it (after you tighten down the retainer bolts), it should be just fine.
PostPosted: Sun Aug 27, 2006 9:51 pm
Summers Bros. is still in business,
a HUGE shop of machines I was envious of...they can do that work, but I do not know that they have the desire to do one off work anymore.
I had them repair a 427 12-Bolt rear axle I have and they only did it because I flashed BIG money at them.
They do great work when they want to;
new management and all, but I think they are only interested in full blown race axle work!
Still a worthy axle shop!
8)
PostPosted: Tue Aug 29, 2006 12:10 am
I had my first set of axles resplined by Summers Bros.
They lasted about a month.
PostPosted: Tue Aug 29, 2006 9:37 pm
Japanese Redneck
what do you think went wrong? Summers Bros has a good name in the axle business.
I had mine done by MIT here it town who i think actually sent them up to Currie. they did the pair for $150 and I have seriously abused the hell out of them since 1994 and they are still alive and kicking.
These days anymore, for a few extra bucks I would just pick up a set of alloy aftermarket axles.
BTW Summers Bros makes the BEST gear drives around too...
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Sep 09, 2006 4:02 am
What went wrong?
Well, the way they explained it to me was that in order to cut off as much as I need to cut off, I would have to have them re-heat-treated. And after they broke they just said, ya, re-heat-treating usually doesn't work.
Not trying to trash Summers Bros, since I've been running a set of their drag axles on the street for about, what, 15 years now? Although they did a shitty job shortening my 9" housing.
Currie does excellent work too. I've used them a couple times and never been disappointed. If I had to do it over I'd just get everything from Currie next time.
PostPosted: Sat Sep 09, 2006 4:31 am
I was also told about the lack of heat treating with the respline . Just bought a pair of 26" Hoosier slicks , can't wait to stress test the whole combo.
