It is currently Mon Jun 08, 2026 2:31 pm
 Post subject: ballest resister
PostPosted: Sun Aug 13, 2006 1:00 pm
Hey I ran my rig for less then 2 min, last night and then put my arm on the coil and the dawm resister burnt me... My question is, is the resister supposed to get that hot. And is it supposed to get that hot that quick? Thanks. Christopher
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
 Post subject: resistor
PostPosted: Sun Aug 13, 2006 1:35 pm
That's what resistors do. They drop voltage and get hot doing so.
PostPosted: Sun Aug 13, 2006 10:10 pm
Both of mine get very hot like that.
PostPosted: Mon Aug 14, 2006 3:23 am
yup it drops the voltage by creating resistance. In electrical stuff resistance causes heat.
PostPosted: Mon Aug 14, 2006 9:20 am
and in most materials heat causes increased resistance.
As I recall it on my trucks the resistor does get up around what I like to call "ouch hot", meaning when you touch it you say "OUCH!".
PostPosted: Mon Aug 14, 2006 8:59 pm
lol. Thanks Im just wondering becaulse of my wiring. When I got the truck it had a broken ignition wire that ran to the resister on the coil (black with yellow stripe I belive). I spliced in a new wire off the existing wire, and the only way it would run is to have the 2 of them hooked up on the resister. And yesterday I was tinking around and cut the stock wire from the ignition and ran only my "new" wire to the resister and it still would only run when I was turning the key over. So I dident know if I was putting a doubble load on it or what... Thanks all. Christopher
 Post subject: resister
PostPosted: Mon Aug 21, 2006 6:47 pm
Many cars have a bypass on the resister for starting. more juice to coil. My luv decided to quit about 20 mi from home and it was the wire from ignition switch to resistor. ait would start but die as soon as key was released from start position.
1980 Luv 4X4
another 1980 luv 4x4
