It is currently Thu Feb 05, 2026 1:06 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: HEY All
PostPosted: Sun Aug 06, 2006 11:44 pm
I haven't been on in a long time so what has change on the site I see that the trivia is gone
I still have not got my Luv fixed yet I am still working on it its still that carb problem
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Mon Aug 07, 2006 4:21 pm
Sounds like you might need to find a new- used carb. for that thing.
PostPosted: Mon Aug 07, 2006 9:10 pm
Banishment Pending
Chavy, I have the old carb off my 80, it was rebuilt about a year ago and has less than 3000mi on it. was in perfect working order when I yanked it off in May to make room for the Weber, I could let you have it for a "small" fee, PM me if your interested, oh and welcome back
PostPosted: Tue Aug 08, 2006 10:58 pm
well the carb I have on it is brand new I just cant adjust the choke on it I had to replace the choke pull and I had take the thermostat for the choke off and now I cant get it to adjust right
79 4x4 1.8 liter
PostPosted: Tue Aug 08, 2006 11:09 pm
rezkid.. pm sent
PostPosted: Wed Aug 09, 2006 7:56 am
Banishment Pending
PM sent back at ya Roadshow
PostPosted: Thu Aug 10, 2006 7:55 pm
so can any one tell me how to adjust it
79 4x4 1.8 liter
PostPosted: Mon Aug 14, 2006 8:52 am
Well I guess I just my help some where eles and just to tell ya I wont be on for a long time
so bye
79 4x4 1.8 liter
PostPosted: Mon Aug 14, 2006 10:07 am
It's just that I don't know how Chavy. If I needed to adj. my own, I would read my book and try what it says and I would probably mess it all up anyway. So I can't help you if I don't know what to tell you.
PostPosted: Mon Aug 14, 2006 10:47 am
Banishment Pending
First off, no need to get pissy
Second off, if no one here has posted on it, it could be that they don't know. What I would do if I were you is I would break out my shop manual (you do have a shop manual I hope) and go strait to the section on carbs and see if what your looking for is there, yet another option would be to ditch the electric choke setup and just put on a cable opperated choke, your local autoparts store should have the kit for $10-20. And then there's also a thrird option...Ditch the POS Hitachi and find your self a Weber, thats what I did and it has been well worth it.
PostPosted: Tue Aug 15, 2006 6:40 am
About how much did that Weber run you rezkid, if ya don't mind me asking///
PostPosted: Tue Aug 15, 2006 7:16 am
so bye
On for a long time, if your gonna be an ass then don't come back at all. Just cuz no one has the info you need, doesnt meen you can be a " DICK " about it chavy, so if you must leave. don't go away mad, JUST GO AWAY :smt039 :smt097
PostPosted: Tue Aug 15, 2006 9:15 am
Banishment Pending
Jingles, the Weber was $115 shipped, I got it from one of the guys on this site in the Classified section
PostPosted: Tue Aug 15, 2006 10:13 am
Chavy, no one has replied to tell you how to adjust your card because each of theses old stock carbs are worn and take different adjustments to make it right. Very few have had any luck getting them right, so the best advice is to replace it with a weber. Most members like to help others but when another comes on here with the attitude that "some one owes them help" it just wont happen. Don't burn your bridges, this is the best site for chevy luv help.
PostPosted: Wed Aug 16, 2006 4:06 pm
well sory for geting mad guys ITs just I have had no luck geting the luv to run right and school starts here soon and I have been geting mad about it so sory guys and nobdy can seem to help me
79 4x4 1.8 liter
PostPosted: Wed Aug 16, 2006 6:53 pm
the best help has been mentioned ..... look at the wrecking yards for a weber (i can jet them here as cores when they have one for $25) get a rebuild kit for $25 and you have the best carb setup for $50 and 30 minuets time
PS i haven't fixed my choke on my stock carb yet either . moved and fiddled with on day and was never right again.....lessen learned never mess with the choke unless going manuel
PostPosted: Wed Aug 16, 2006 7:30 pm
Chavy is in Cal. and has to deal with smog inspections every other year. Same as me.
Chavy, try adjusting the choke to all the way open so it's basically not doing anything and see what happens. That's how I have my 80 right now and so cal in the summer , It has an attidude in the morning and then it runs fine in about 2 blocks down the street.
PostPosted: Wed Aug 16, 2006 8:34 pm
Rondog what do you mean by you have it all the way open
79 4x4 1.8 liter
PostPosted: Wed Aug 16, 2006 8:39 pm
oh yeah i forgot california smog
PostPosted: Wed Aug 16, 2006 9:36 pm
chavy.. what rondog means is he turned the choke cover. what you do is loosen the 3 screws around the plastic cover and turn it towards you as you stand on the passenger side of your truck. there are little tic marks on the carb and a single line on the cover and to open it al the way up, the line on the cover should line up with the last tic mark on the carb. it will make it a bit harder to start in the morning, but once it warms up you should be fine. once you get it running, you can slowly tweak the choke back towards closed until you are happy with it.
