It is currently Mon Jun 08, 2026 10:55 am
 Post subject: Factory 4X4 rims ???
PostPosted: Thu Jul 27, 2006 10:39 pm
anyone out there still running the factory 4x4 rims and caps? I need to know how the caps attach and what lug nuts are used with the caps..
PostPosted: Thu Jul 27, 2006 10:40 pm
They had cap's on'em??????? 8O
LMFAO!!!!!!
Looking for that special LUV.
PostPosted: Thu Jul 27, 2006 11:10 pm
yep.. 8O
and i've got a couple... :roll:
PostPosted: Fri Jul 28, 2006 10:47 am
sorry so late Bob! They came off my truck with the stock 14" white spoke rims, I think they used acorn nuts or somthing. Sorry I dident have a full set though :cry: . Enjoy!~! Christopher
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Fri Jul 28, 2006 3:39 pm
They are the same as what came on my 86 trooper if that helps. The nuts have a straight round section between the wheel and the bolt shaped end. There is a washer that fits over that straight part of the nut, but not over the bolt shaped end, and then a sort of wave spring washer. The two washers fit agains the lip of the hole on the center caps somewhat loosely, and the end of the nut goes right on through to make solid contact with the wheel.
I'm trying to get some pics taken for ctmandu of my tilt column so I'll try to snap a shot of one of the lug nuts for you at the same time.
PostPosted: Fri Jul 28, 2006 6:45 pm
thanks fellas....
Christopher.. I appreciate the parts..
800xl... the pic would be a great help
Users browsing this forum: Google [Bot] and 58 guests
