It is currently Thu Feb 19, 2026 10:14 pm
PostPosted: Sat Jul 15, 2006 9:10 pm
I started to swap to the electronic ignition today. I marked my advance and rotor positions and yanked my old Opel/Isuzu distributor out. I stabbed the new one in and the only way to get it in is with the rotor 180 degrees from where to old one was. I removed my old coil and bracket and bolted the newer one (external module mounted on it) in. The instructions i got with mine said to use the positive from the ballast resistor to positive on the coil. Resisitor bypass wire taped off, plug in the harness to the coil and the shieled wire to ground. My problem is this, there were three black wires with red stripes and one went to either end of the resistor and one to the positive onthe coil, in addition to the black/yellowish striped wire that went to the negative coil. Which one do I use on the positive side of the coil? It's a 1980.
PostPosted: Sun Jul 16, 2006 12:27 am
How many wires coming from the dizzy?
PostPosted: Sun Jul 16, 2006 12:34 am
the only wires from the distributor are the ones in the plug
PostPosted: Sun Jul 16, 2006 12:39 am
sounds like a road trip to the yard to see first hand
PostPosted: Sun Jul 16, 2006 12:53 am
btw it's from a mid 80's trooper
PostPosted: Sun Jul 16, 2006 9:22 am
So it should have the internal module instead of the one the sits on the coil. Mine is from an 85 trooper and is all self-contained
PostPosted: Sun Jul 16, 2006 12:24 pm
it's got the internal module and I think an igniter on the coil bracket.
PostPosted: Sun Jul 16, 2006 5:52 pm
ok on mine i have 2 wires one black and the other is black and yellow the black went to - and the y/b went to+ hope this helps a little
PostPosted: Mon Jul 17, 2006 12:37 am
thanks for the help.. i'll see what i can figure out in the next day or two...
PostPosted: Wed Jul 19, 2006 11:13 pm
just took another look at this damned thing and it's got an external module/igniter and what I thought was the module is the pickup coil.. stupid me... anywho, anyone else out there that has any ideas???
PostPosted: Mon Jul 31, 2006 11:13 pm
Well I got it running today with some help from the JoeIsuzu's forums ... although apparently my old Opel/Isuzu distributor was 180 out ???? :roll:
PostPosted: Wed Aug 23, 2006 11:51 pm
Is this one similar to the one you sold me? I'm thinking about installing that thing finally...
PostPosted: Thu Aug 24, 2006 10:41 pm
The one you have is from an 81/82 LUV.. mine is from an 81 I-Mark. I believe they are the same.
PostPosted: Wed Aug 30, 2006 6:28 am
PITA Old Fart
Yep..I'm running an Imark ignition module and Accel custom coil with a truck distributor and it runs excellent.
It sure has made a difference in power and drivability.
Also...check your vacuum advance diaphram because the older japanese ones are notorious for leaking and they are cheap and can easily be bought at just about any parts store.
