It is currently Mon Jun 08, 2026 10:54 am
 Post subject: CV BOOTS
PostPosted: Wed Jul 12, 2006 9:39 am
First time poster here, I got a quick question, has anyone ever tried to put cv boots on the front axles of a 1980 4wd chevy luv. If so what procedure did you use. thanks
PostPosted: Wed Jul 12, 2006 10:28 am
To do it right is pretty involved. You want to get boots that are solid, not the split kind. Those split ones are pretty much junk, might as well just not replace them if that is what you want to use. The problem is that the non-split boots require you to take everything apart, starting at the hub, then the spindle, the ball joints, etc etc. You have to get down to just the shafts in order to slide the boot on.
It can also be tricky getting the bands tight and secure on the ends of the boots. There is a tool you can get for putting them on there nice and tight, but it can be done with just hand tools if you work at it.
 Post subject: boot replace
PostPosted: Sat Jul 29, 2006 12:05 pm
I just changed the boots on my 1980 4x4. I found some split boots that bolt together rather than glue. The glue type are junk. I found these guys on the net either carparts.com or advanced auto. They worked very well. I think O'reilly had them also.
1980 Luv 4X4
another 1980 luv 4x4
Users browsing this forum: Google [Bot] and 57 guests
