It is currently Fri Apr 17, 2026 11:20 am
 Post subject: Water spotted windows
PostPosted: Wed Jun 21, 2006 2:04 pm
Anybody know how to remove very old, very bad, water spots from the windows and mirrors?
I've tried CLR, vinegar, lacquer thinner. Any other ideas?
PostPosted: Wed Jun 21, 2006 2:18 pm
Rubbing compound usually does the trick. Then you'll need to get rid of the flim left over with regular window cleaner.
PostPosted: Wed Jun 21, 2006 5:01 pm
take coke'a'cola and pour it down the window, or rub it on w/ a cloth on a mirror, let it get just a little tacky, then use a scotch brite pad, the guy that did my windsheild on my luv did it to my old one, cleaned up good...
PostPosted: Wed Jun 21, 2006 5:41 pm
I have that problem as well. I have been told costic acid (pool cleaner) will work. My neighbor is a pool repair man so I will try this by the end of the week.
PostPosted: Wed Jun 21, 2006 9:30 pm
CLR should work eventually, or Lime-Away.
Maybe they will take a while. Try letting it soak?
Or try one of these other ideas...
PostPosted: Wed Jun 21, 2006 10:20 pm
at the shop we use a sponge and wheel acid, so i am sure any acid cleaner would work. we use wax or rubbing compount on light spots, the hard ones need scrubbing and acid
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Thu Jun 22, 2006 4:10 pm
Scotch bright pad scratched my slider window. I'm using CLR straight and also using Eagle etching aluminum wheel cleaner ( LUVRV8, gee, why would I have a fresh bottle of that? :D ). It's basically acid and is helping. but spots are still there. Polishing compound didn't seem to work.
I wish the calcium on my teeth was this strong. :lol:
PostPosted: Thu Jun 22, 2006 6:34 pm
Sorry Ron, I thought everybody had a neighbor who builds and repairs pools.
PostPosted: Thu Jun 22, 2006 7:21 pm
About 20 years ago I was a pool cleaner for a summer in Sacramento.
My first job was in a pool store in Fullerton. And I grew up with a built in pool / spa in the back yard. But now days , I'll just have to go beg at the local pool store for a cup of acid. :lol: (Makes me sound like a junkie).
PostPosted: Sat Jun 24, 2006 12:58 am
I got some pool acid and it didn't work. I tried vinegar and no go.
I think trying everything over and over has helped a little, but spots are still there. It has worked best for the aftermarket mirrors.
 Post subject: Spots
PostPosted: Sat Jun 24, 2006 8:53 am
Coca Cola is what we found would work back in the days of my military service.
