It is currently Sun Mar 22, 2026 5:52 pm
PostPosted: Fri Jun 16, 2006 1:09 am
can i get sum pics of v8s in luv's i have a 75 luv with a 350 id like to see haw you got yours set up ... my luv gets hot fast.
PostPosted: Fri Jun 16, 2006 4:22 am
Here's mine I have put on a homemade shroud since then. The temp. on mine stays around 190 it goes up to 210 in really heavy traffic. I got a 400 in front of a super T-10 and a 22x19 griffin radiator.
http://forums.luvtruck.com/viewtopic.php?t=8464
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jun 16, 2006 7:59 am
Here's pics of mine. Only difference now is that I have the electric fan on the front of the radiator.
http://forums.luvtruck.com/viewtopic.php?t=10180
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Fri Jun 16, 2006 12:52 pm
Here's a pic of the motor located in the frame. Hooker mounts and headers were used.
PostPosted: Fri Jun 16, 2006 1:09 pm
Swap Specialist Mod
heres a pic of ezekiels truck withthe mock up motor in it.
this is one of peeroys 78.
one of ricks truck
chets truck
and codys truck
PostPosted: Fri Jun 16, 2006 9:16 pm
Heres a couple of mine.
PostPosted: Sat Jun 17, 2006 12:25 pm
Mine in mock up.
PostPosted: Sat Jun 17, 2006 8:58 pm
what radiator do all of you have i have a stock one..
PostPosted: Sat Jun 17, 2006 9:11 pm
A 19" X 22" aluminum crossflow seems to be the most popular to go with. What brand to use is up to you. A trans oil cooler will be required if you dont pony up for a radiator that has a built in cooler.
PostPosted: Sat Jun 17, 2006 11:12 pm
Zactly!!!
PostPosted: Sat Jun 17, 2006 11:26 pm
Electric fan on the front of the radiator too. You can wire it up to work with a temp switch or constant with the key on. A relay is a MUST!
PostPosted: Sun Jun 18, 2006 8:23 pm
i have a Electric fan on the stock one....where do you cut for the new one?
PostPosted: Sun Jun 18, 2006 8:28 pm
Electric fan on the stock one? Make a cut? Can you be a bit more specific with what you have now? Do you mean to find out where to cut the radiator support to fit the new aluminum radiator?
PostPosted: Wed Jun 21, 2006 3:05 pm
i mean to find out where to cut the radiator support to fit the new aluminum radiator?and what radiator will work good so i can drive it more thin 300yrs with out it geting way up there i have a stock radiator in it naw and if i turn the fan on 1st it will say about 200 or so but i het the gas and it will jump up fast...do i need a tranny cooler too?
PostPosted: Wed Jun 21, 2006 3:29 pm
Here's a basic drawing to go by. With a V-8, you'll need to either create some room up underneath the support top. Or fabricate a cutout section that you can remove to make removing the radiator or engine easier. Take a look at LUVINIT's pics. He cut out the support just enough to fit the radiator. I wish i had the top section from my truck still. But it's long gone and i would have reworked it to be made removeable.
The stock radiator cant handle the cooling of a V-8 so forget about using it. Modifying a stock unit to work isn't practical because you'll spend too much money and it wont work as well as an aluminum unit.
A trans cooler is a must if you want your transmission to survive. I had my old trans looped off for a long time and i was lucky it held up like it did. Get a cooler... Pulling the motor to remove a bad trans because you didn't install a trans cooler is a waste of time and money. And once you get the new trans back in and everything else installed, you'll have to install a cooler to save the new trans.
Users browsing this forum: No registered users and 64 guests
