It is currently Mon Jun 08, 2026 12:14 pm
 Post subject: Cab switching
PostPosted: Tue May 16, 2006 7:35 am
I will ramble a bit. want to get it done.
Is switching the cab a huge job or what. I look at it this way ny truck needs wiring and the other cab is all wired up. still needs work in the floor but roof is not buckled. Other thing is are doors with the vent window or wing windows is to convert to the later version without my 74 doors are better then my 79 but the bed and bumper are all better so it will be titled as a 74 or should it be titled as a 79 as the frame of the 79 is wasted. the trouble or bigest question is Removing the steering colume and wheel.
really the more I think about the job is I am taking the 74 frame and turning it into a 79 4x4 stick even thought i wanted 2 wheel at so anybody interested in trading a good auto for the 4x4 stick tranny
PostPosted: Tue May 16, 2006 8:11 pm
I removed the cab and bed from my 74 and replaced it with a 78. The job was not too hard or bad at all.
PostPosted: Wed May 17, 2006 11:57 pm
did you re-title it as a 79 because the cab#have to match the pink slip
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu May 18, 2006 12:14 am
just keep the title like it is that is too much hassle,just drill out the rivets on the serial# plates and swap them.
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
PostPosted: Thu May 18, 2006 10:14 am
My truck is titled as a 74. Here in Ca we go off the frame for years.
PostPosted: Thu May 18, 2006 5:07 pm
how can they tell on a luv what year the frame is? Seems like the only numbers I've seen are in paint and most of the time pretty much obliterated...
Resident lurker
PostPosted: Thu May 18, 2006 5:25 pm
It was a long process, but worth it in the long run.
