It is currently Sun Mar 22, 2026 6:08 am
PostPosted: Fri May 05, 2006 9:31 pm
So I have a nipple that comes off the square plunger thing on my carb, that if you put vac to it, it opens up the secondairies. It is plugged off now, but doesnt the secondairies work off internal vac from the carb? What gets hooked to this vac port????
PostPosted: Fri May 05, 2006 11:23 pm
Swap Specialist Mod
the secondaried work off the carb. as the motor draws a certain amout of vacuum the secondaries open. thats the whole theory behind the vac secondary.
PostPosted: Fri May 05, 2006 11:27 pm
So what about the nipple thing stickin off the side? I have it plugged now, but whats it for? I R so stupeed!!!
PostPosted: Sat May 06, 2006 12:16 am
Swap Specialist Mod
that i dont know
ill have to look at one to know what it is.
PostPosted: Sat May 06, 2006 1:23 am
I'll get up a pic!!!
PostPosted: Sat May 06, 2006 11:26 pm
Japanese Redneck
btw you can get a spring pack for the vac secondaries its a variety pack. the lighter the spring you put in there the sooner the secondaries open. they also have a quick change kit for it so you can swap it without tools.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun May 07, 2006 1:33 am
So my buddy Frank, just looked at it, and he is leaning towards some kinda of emissions, or somethingk it could have been hooked to like the wipers, or cruise control, something in that nature. I do need to do some research on this carb, and find out what it came off of.
PostPosted: Sun May 07, 2006 1:36 am
Swap Specialist Mod
is it the carb on you luv right now? do you have a pic of of?
PostPosted: Sun May 07, 2006 1:39 am
Yes, its a holley 650 ( I think :P ) I dont have a pic right now, but I will get one tomarrow when I have some sun light!!!
PostPosted: Sun May 07, 2006 1:41 am
Swap Specialist Mod
huh... wierd. ill check around and see if i find anything about it. 8O
