It is currently Wed Jun 10, 2026 10:13 pm
 Post subject: What to do?
PostPosted: Mon May 01, 2006 11:26 am
Hey guy's :smt040 . I'm gonna do a compression test this week on my spare motor, and if it turns out good, this will be going back into my luv. If the compression is low, then I am forced to rebuild this motor. This is a brand new schucks rebuilt motor, that sat (in the truck) for 7 years in a forrest with no spark plugs in it. I am taking things apart and I am finding that the motor is real clean on the inside. who knows it could turn out as a runner. I will let you all know the results from the compression test, as this will deside the fate of my motor.
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Mon May 01, 2006 8:50 pm
Good luck!!! I hope its all good!!!
PostPosted: Mon May 01, 2006 10:54 pm
Ditto 8)
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Mon May 01, 2006 11:24 pm
Swap Specialist Mod
did it have a hood on it while it wa sittin? if it did just put some ATF dwon the plug holes, let it sit for a day and turn it over.
was it ran any before it was parked?
PostPosted: Wed May 10, 2006 9:06 pm
in order to do an acurate comp. test you need to get the engine warm first. Other wise it will just tell you that its making compression, not how much...
PostPosted: Wed May 10, 2006 9:54 pm
and I dont see that happening on the stand!
PostPosted: Wed May 10, 2006 11:27 pm
just put your ratchet on the crank and crank really really fast for about 20 minutes or so and you will be fine :lol: :lol: :lol:
PostPosted: Thu May 11, 2006 2:12 am
I dont know about these 4 cyleders but if the starter bolts to the block just bolt up a starter and hook it up to a extra battery.
or maybe this is a dumb idea and i should stick to small block v8's.
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
