It is currently Mon Jun 08, 2026 10:55 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Apr 22, 2006 10:21 pm
the carb cut off solinod is fine
This is a new carb on it
o sory my cap lock key was on
I here or see no vacum leaks
when I pore gas down the carb it will idel off that its just starving for gas at low idel
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Apr 22, 2006 10:25 pm
Luvtruck.com Wookie
that's fine .....re read that post a little closer and you'll notice that the possible problem is not the carb, but the wiring between it and the engine speed sensor.
TiLtEd wrote:
Boobies!!! :D
Well, than good luck :?
PostPosted: Sat Apr 22, 2006 10:29 pm
what in the carb controls the gas from the end off the line to the carb its self I see no gas goin into the carb when I look down in it and I now theres gas going to it
79 4x4 1.8 liter
PostPosted: Sat Apr 22, 2006 10:32 pm
dude i have no idea i dont see how you are getting gas to the carb but you cant see any in the lines or what not. you lost me
PostPosted: Sat Apr 22, 2006 10:34 pm
I have pulled the fuel line to the carb to check it and its pumping out gas but the carb is not realy doing any thing its tacking the gas but its not leting it go to the bowel
I think
79 4x4 1.8 liter
PostPosted: Sat Apr 22, 2006 10:37 pm
Luvtruck.com Wookie
just hotwire the solinoid..... see if it helps...... the problem was intermittent on my truck. that solinoid is the only thing that can stop fuel between the fuel line and the bowl.
i know what i'm talking about so if you're gonna dismiss my advice without even checking to see if it will help, then you really don't want it and i'll stop offering.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Apr 22, 2006 10:40 pm
now if it was not working would it still run if I am on the pedal cus thats the only way it runs beside puting gas right down the carb
79 4x4 1.8 liter
PostPosted: Sat Apr 22, 2006 10:45 pm
chavy.. just take a few minutes and check the solenoid.. where's all the luv at knows what he's talking about....
PostPosted: Sat Apr 22, 2006 10:46 pm
chavy are you always this hard headed?
PostPosted: Sat Apr 22, 2006 10:47 pm
Luvtruck.com Wookie
yes it will run with the throttle open if the solinoid isn't open
my truck would stop idiling intermittently and i'd have to crack the throttle open slightly to get it to run and it ran fine on the freeway in this condition.
if you're worried about screwing up your wiring get 2 alligator clips and 3 foot of 12 gau or thicker wire to jumper it with. you ain't gonna hurt anything trying this. just don't drive it around till you get it hooked up to the hot lead to the coil.
it ran for 6 months hotwired before i scored a weber and i never had it happen after that.
Thanks bob..... you're probably the only person i've heard say that in a long while........
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Apr 22, 2006 10:50 pm
just giving props....
PostPosted: Sat Apr 22, 2006 10:52 pm
I tested it it works I just wont be able to drive it untill morning but the solinoid works so I am hooping for the best
79 4x4 1.8 liter
PostPosted: Sat Apr 22, 2006 11:10 pm
Good. Now say thank you.
PostPosted: Sun Apr 23, 2006 12:20 am
thank you guys
79 4x4 1.8 liter
PostPosted: Sun Apr 23, 2006 1:25 am
Swap Specialist Mod
holy triple post batman!! :D
PostPosted: Sun Apr 23, 2006 1:44 pm
well that was not the problem the trotale plate wont close unless I colse it by hand the mecanisum is bad so I am going to see if a buddy of mine to look at it
But thanks any way for the help
79 4x4 1.8 liter
PostPosted: Sun Apr 23, 2006 6:23 pm
FYI chavy, if there's a throttle plate or anything like that on a vehicle, it has to stay partly open.... engines need air to run, if they closed ALL the way they'd just shut off.... Maybe yours wasn't opened up enough at idle to supply the air it needed.
PostPosted: Sun Apr 23, 2006 6:34 pm
ITS THAT PLUNGER THing that controls it thats mest up what its doing the plate is staying to far open to idel I have a ex carb and use that punger
79 4x4 1.8 liter
PostPosted: Sun Apr 23, 2006 8:00 pm
So is it fixed?
Users browsing this forum: Google [Bot] and 56 guests
