It is currently Mon Jun 08, 2026 11:54 am
 Post subject: The right Weber
PostPosted: Sun Mar 26, 2006 6:00 pm
Ok I have an 81 4x4 with the 1.8. I know I need the 32/36 but I belive I need the auto choke right?
Can a mech choke be made to work with my truck?
With my limited finances I do not want to make a mistake.
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Mon Mar 27, 2006 1:25 am
A manual choke will work, but you'll need to run a cable into the cab somewhere. The electric auto choke just makes it easier to drop on and run. Avoid the water activated choke unless you want to do a pretty intricate plumbing project.
PostPosted: Mon Mar 27, 2006 8:22 am
Pardon my ingorance,
Is that the
DGEV
DGAV
or something diff?
Rigel
 Post subject: choke
PostPosted: Mon Mar 27, 2006 9:08 am
dgev
PostPosted: Mon Mar 27, 2006 3:21 pm
You dont need no stinking choke. :lol:
i dont have 1 on my luv .
i just like it with out it . ihave all was had probles with it .
ethere its working to good or not at all. :x
PostPosted: Sun Apr 02, 2006 7:31 pm
Does "IT" have to be a dgev or will any electric choke work?
I have seen these on ebay.
http://cgi.ebay.com/ebaymotors/Weber-32 ... 6901QQrdZ1
http://cgi.ebay.com/ebaymotors/BMW-2002 ... 3720QQrdZ1
http://cgi.ebay.com/ebaymotors/Weber-Ca ... 8789QQrdZ1
Thanks
Rigel
PostPosted: Sun Apr 02, 2006 8:51 pm
get an electric choke itll take a fewmornings to adjust it perfectly but its the way to go !!!!! :smt030
PostPosted: Mon Apr 03, 2006 9:37 pm
Well I got a Weber 32/36 DGAV, I hope I can make it work.
If not then back on ebay it will go.
There were no DGEV's To be had for the money I had.
Rigel
PostPosted: Mon Apr 03, 2006 11:53 pm
DGV, DGEV, DGAV are all the same carb body so it will fit. They are all basically a DGV. The different models might have an extra vac port here or there or different chokes but the base carb is the same. If its one of the three and has an electric choke, then its what you are looking for.
Users browsing this forum: Google [Bot] and 15 guests
