It is currently Sun Nov 09, 2025 10:22 am
 Post subject: Whats red line on Luvs
PostPosted: Tue Mar 14, 2006 10:08 pm
whats red lining Luvs cause I got mine up to 6000 rpm
I heard they can get up to 10000 so whats red line
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Mar 14, 2006 10:18 pm
Swap Specialist Mod
well it all depends on how your motor is built. if its just a stock motor i wouldnt take it much more past 6000, but if you have it built and balanced and all that stuff, itll prolly do 8500-9000 pretty good.
i personally take the pup to about 6500 every once and a while. it gets to goin.
PostPosted: Tue Mar 14, 2006 10:25 pm
I had just ran some high engine cleaner the truck has like 10 more hores now
79 4x4 1.8 liter
PostPosted: Tue Mar 14, 2006 11:36 pm
coming out of a parking lot i powershifted mine at 8,000, then i wound it up to 6500and power shifted again. Sometimes i am truly amazed my truck hasnt just said "F you man, im dead!" :lol:
PostPosted: Tue Mar 14, 2006 11:43 pm
so when its up to like 6000 dose the HP increase
79 4x4 1.8 liter
PostPosted: Tue Mar 14, 2006 11:56 pm
Banishment Pending
Peak HP is around 4500-5000rpm
PostPosted: Wed Mar 15, 2006 9:19 am
even tho it was up to 6000
79 4x4 1.8 liter
PostPosted: Wed Mar 15, 2006 12:49 pm
Banishment Pending
depends, some engine lose power as the rpm's get much above 5000rpm, I don't think the Luv has one of those engines, I've had mine rev'd up to at least 6500rpm a couple times, seems to pull really good up there, so I'm guessing that up there it's still making 80hp or so.
PostPosted: Wed Mar 15, 2006 2:29 pm
Chavy, if you keep running at above 6k, you will soon see your connecting rods outside of your block.
PostPosted: Wed Mar 15, 2006 4:15 pm
We never let mine go above 3000, :( because the bad wrist pin really gets to knockin. I wind it up now and then, but I'm just waiting for it splode! 8O
PostPosted: Wed Mar 15, 2006 5:42 pm
Banishment Pending
Normal driving, I don't let it get above 4500, most of the time I stay around 3400 or so, I'd like the engine to last me until i can get a 2.6 built up and in.
PostPosted: Wed Mar 15, 2006 11:46 pm
i had my cam ground to make HP from 3000-5000. Stock the cam gives you peak HP at 4800rpm. Past that your only making noise. Stock cam also gives you peak torque at 3000. How i have always drivien my truck is rev it up to peak HP then the next gear drops you back down to your peak TQ rpm. But honestly most all Isuzu engines are realy made to rev out hard. And your doing more damage to em by shifting it at 2000rpm than you are shiting at 6000rpm...
PostPosted: Wed Mar 15, 2006 11:48 pm
Swap Specialist Mod
MEPR, i want you cam... and uhh, the whole motor! lol :lol:
PostPosted: Wed Mar 15, 2006 11:49 pm
well unfortunatly the cam is already spoken for by another buddy of mine whith an Imark. But the rest of the engine whith out that cam wil soon be for sale and i would guess it would make in the nieghborhood 110-120hp. Even before the cam i could 3pedal power brake it with 30" BFG A/Ts on dry pavement....
PostPosted: Thu Mar 16, 2006 8:58 am
I totally forgot to talk to my eng. guy about a putting in a better cam. :evil:
Oh well. too late now.
PostPosted: Mon Mar 20, 2006 11:11 pm
MEPR: Where'd you get your cam done, and what spec's did you use (throw me a bone here, man!). :lol:
PostPosted: Tue Mar 21, 2006 3:45 am
i just told delta cams here in tacoma i wanted a cam that would just boost hp and tq a little bit within the factory power band. They did the rest. Youll just have to provide a stock cam so they can use it for the re-grind...
Users browsing this forum: Bing [Bot] and 26 guests
