It is currently Sun Apr 12, 2026 6:00 am
 Post subject: is...............
PostPosted: Sun Mar 12, 2006 1:05 pm
is the coil supost to get hot when i try to start my truck
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Sun Mar 12, 2006 1:28 pm
Banishment Pending
think about it, it has some where around 30,000+ volts running through it when the engine is running/starting. So yeah it is going to be a little warm when your trying to start the engine
 Post subject: Coil
PostPosted: Sun Mar 12, 2006 5:23 pm
Just warm, not hot, except from engine heat. If its hot in the shade with the hood open while the engine is running, the coil could be partially shorted, causing a larger current draw. This would possibly make the engine hard to start if not impossible at times.
PostPosted: Mon Mar 13, 2006 8:25 pm
well it feels like i can fry an egg on that thing so it might be time to put the new one in
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Mon Mar 13, 2006 9:25 pm
Banishment Pending
yup sounds like time for a new one, AutoZone has them for $34
PostPosted: Mon Mar 13, 2006 10:19 pm
napa 10 bucks
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
Users browsing this forum: No registered users and 71 guests
