It is currently Wed Jun 17, 2026 3:04 am
 Post subject: Got me a boat
PostPosted: Thu Feb 16, 2006 3:58 pm
this boat was given to me by my uncle he said take it
It is a 17 footer nothing big a great fishing boat and something to tow with the Luv
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Thu Feb 16, 2006 5:41 pm
Towing won't be so bad, but stopping will be fun.
PostPosted: Thu Feb 16, 2006 7:55 pm
Exactly what I was thinking.
My 15 footer will be bad enough. Although I've pulled that one around by hand! 8O
Steve
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Fri Feb 17, 2006 1:36 am
What kind of boat is that Chavy? Free is a good thing.
But the others are right about towing it behind your Luv. I'm a big rig driver and have a lot of experience pulling a lot of weight. Stoping could be dangerous. Don't follow too close and watch for brake lights 5 or 10 cars up so you can start slowing before it becomes a panic stop.
PostPosted: Fri Feb 17, 2006 5:36 pm
can Luvs have trailer brakes
79 4x4 1.8 liter
PostPosted: Fri Feb 17, 2006 5:56 pm
There are different kinds of trailer brakes. Boat trailers usually have surge brakes which is drum or disc on the axle, hydraulically operated by a master cylinder on the tongue. When the truck is slowing, the weight of the trailer pushing forward on the hitch, applies the trailer brakes. This kind of set up will work on any vehicle towing it.
Electric brakes found on most travel trailers require some specially installed equipment on the towing vehicle.
I suggest you take the boat to a public scale and find out what it weighs, (boat trailer engine) and check what the owners manual in your Luv says. If you don't have one I'm sure someone here could help with that.
PostPosted: Fri Feb 17, 2006 6:55 pm
if i remeber corectly a LUV is only rated to tow 1500lbs.
