It is currently Mon Jun 08, 2026 4:23 pm
 Post subject: Radio
PostPosted: Tue Feb 14, 2006 8:37 pm
How was the stock wiring set up for a Luv. My Luv has had stereos in and out of it I want to make it so its not so mest up
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Feb 15, 2006 12:04 am
The stock radio has just one blue wire tied to key on power. Anything else has been added by someone else. The stock speaker was under the center of the dash, wired directly into the radio.
PostPosted: Wed Feb 15, 2006 12:40 am
so Luvs came with one speaker
79 4x4 1.8 liter
PostPosted: Wed Feb 15, 2006 2:42 am
Yes on the center of the dashboard.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Feb 15, 2006 2:53 am
Chances are, it is still in there.
PostPosted: Wed Feb 15, 2006 9:19 am
I have to floor speakers that look as old as the truck
79 4x4 1.8 liter
PostPosted: Wed Feb 15, 2006 9:27 am
Banishment Pending
After market stuff added on later by the dealer or previous owner
PostPosted: Wed Feb 15, 2006 10:51 am
Just rewire the stereo in new powerwire, speakerwire, ect. that way you know its done with all new wires no problems. I wrapped all my wire in eletrical tape, good connecters and lots of shrinktube. You can fit 6x9s on the side wall of the cab, just box it and add a can of expansion foam to seal it in. Seats protect the speaker and no on can see them. You cram 6"s in the doors easy. After your done buy Slipknots new live album and Rage On.
PostPosted: Wed Feb 15, 2006 12:41 pm
Banishment Pending
You can also fit 5 1/4" into the kick panels, just do the wiring yourself, that way you know it's done right. Thats what I did this summer, rewired my whole stero system.
PostPosted: Wed Feb 15, 2006 1:54 pm
I've always been able to use the stock power wire, but never put much of a head unit in my truck so it didn't matter much. The 4 luvs I've used as daily drivers also didn't have much done to destroy the interior wiring either. If it looks screwy, you are better off to abandon original wires and run your own.
PostPosted: Wed Feb 15, 2006 7:57 pm
My 81 had 4 " full ranges in the kick panels stock.
I am not sure what I will put in once it is on the road.
I most likely will get some my old sealed jensen 2ways with a cheapo am/fm radio from autozone. Its a work truck after all.
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Wed Feb 15, 2006 8:25 pm
yea the two floor speakers must be a dealer option My truck has alot of dealer ad ons
79 4x4 1.8 liter
PostPosted: Wed Feb 15, 2006 8:29 pm
The holes for the 4" are built into the cab sheet metal so it has to be factory.
They are real shallow though about 1 3/4 deep be a bitch to find speakers to fit that.
Rigel
PostPosted: Wed Feb 15, 2006 9:08 pm
I forgot about the 81-82, they did have stock kick panel speakers. 72-80 did not though.
I've never seen a dealer option speaker set on 72-80, could be possible, but more likely some prior owner did a good job of putting them in. My side pocket behind the seat 6x9s look like they came from the factory, because I spend a couple days perfecting everything on them. Shoot, I even mounted carpet under the seats and back to the corners to cover the wires.
