It is currently Thu Mar 26, 2026 3:03 am
PostPosted: Sat Mar 01, 2003 9:12 pm
My father ask me this question and i did not have an answer so I am asking here
Thanks
Rigel
Gareth
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Sat Mar 01, 2003 10:32 pm
All of the 4.3's I have seen have a 700r4 behind them.
PostPosted: Sun Mar 02, 2003 11:14 am
correct me if IM wrong, but i believe they can hook up to anything a 350 will take!? Its basically a 350 with two cut off, right.
sorry, but anytime anyone starts talkin 4.3, you know i start getting moist and sweaty :twisted: i dig that motor.
PostPosted: Sun Mar 02, 2003 10:07 pm
the 350"small block 283-400" and the 4.3 share a lot of parts -the water pump the rods, pistons ,lifters,push rods,timing chain,dampner,flywheel,and to answer your question any trans that bolts to a small block will bolt to a 4.3
PostPosted: Sun Mar 02, 2003 11:01 pm
Yah, they have the same bolt pattern as a small block v8. Th350, TH400, 700R4, 4L60, 4L80, 4L60E, and 4L80E should work.
