It is currently Tue May 26, 2026 7:40 am
 Post subject: stock engine or upgrade?
PostPosted: Sat Feb 11, 2006 11:01 am
im curious...i have a 79' luv 4x4. im not a mechanic by any means and want to get it back on its feet with as little money as possible...should i have the 1.8 rebuilt or should i put a different motor in? and if different motor is the general concensus...which motor is a good, common one that i can throw in without having to change much else besides the tranny?
PostPosted: Sat Feb 11, 2006 3:19 pm
Rebuilding your engine will be your most cost effective method,swapping to a different motor can get costly and involved.
PostPosted: Sat Feb 11, 2006 8:28 pm
a rebuild would probobly be the cheapest road to go but you can swap in a nice small block or even a V6 without an extremely large amount of cost. But if you are goin bottom dollar, a rebuild would be the best option, unless you can find a 305 or somthing in a junkyard
79 luv drag truck
2 skidoos
2 quads
badass duramax diesel
 Post subject: motor
PostPosted: Sun Feb 12, 2006 10:01 am
Remember you loose your 4x4 with any other engine but luv or Izuzu 1.9.
Rebuilding luv engine is easy and not to expensive. There are also a lot of good used engines around. Iv'ed had my 80 4x4 for over 20 years and (luv) it.
1980 Luv 4X4
another 1980 luv 4x4
