It is currently Wed Jun 17, 2026 2:32 am
 Post subject: vin numbers
PostPosted: Thu Feb 09, 2006 8:29 pm
can you guys help a dude out i got a luv it needs to have a inspection by the chp they said there is one vin on the cab and one on the frame i have the cab one do you know where the frame one is please help a guy out oh the one on the hood is there but the hood is off a onther truck
PostPosted: Thu Feb 09, 2006 8:51 pm
I have never seen the VIN on the frame. Some early models have it stamped on the body near the right wiper arm just below the cowl and where the hood meets the body. The VIN plate is pop riveted on the drivers side door jam and a sticker is on the drivers door.
I found this from 800xl with the SEARCH button
There is also a stamping of the last few digits under the cowl panel (louvered chunk of sheetmetal between the rear edge of the hood and the windshield) and I have heard that it can be found on the frame right near the fuel tank. The one under the cowl is stamped into the sheetmetal of the cab. I have never had a reason to look for the one on the frame, but I've read a couple of posts here that mention it might be there.
The only other thing I've seen is a painted stencil of part of the vin on the outer side of the frame rail on the passenger side of the truck. It is usually completely illegible though, if not painted over completely. I assume some of the numbers on the block of the engine can be connected to the VIN, but I have not found the VIN number itself anywhere on the motor.
 Post subject: thanks guys
PostPosted: Thu Feb 09, 2006 9:13 pm
i will look
PostPosted: Fri Feb 10, 2006 12:06 am
why do you need to find the vin numbers? I know it's stamped on there in quite a few places but I can't tell you exactly where. I could show you every single one on a honda, but I guess that doesn't help....
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
 Post subject: found vin
PostPosted: Sat Feb 11, 2006 1:46 am
i found the vin on the cab under the cowl thinks guys 4 the help.i got a luv from a towing yard and it is from out of state so the chp needs to verify the numbers. the towing yard got the number off the hood and it's not the stock hood it's off a76 and the truck is a 75 so thats the hole taco (bud out)keep up the good (luv)
PostPosted: Sat Feb 11, 2006 11:47 am
The normal place for the VIN is on the door pillar on a metal tag. Should be plainly visible when you open the driver's side door. If the doors are original it is on a sticker with the GVWR info too. My old post was more about the exotic places you might find it if you had to. I didn't think about the hood, in fact I didn't think the VIN was on those stickers, just some engine family number or something.
 Post subject: vin is good
PostPosted: Thu Feb 16, 2006 8:49 pm
i got my luv taged and it is a 1975 nooo smog sweat dude now i want to but a 89 isuzu trans and rearend in it and primer the li'l truck
Users browsing this forum: Bing [Bot] and 10 guests
